Metal DC power Jacks
Frequently asked questions regarding powering your pedal.
DC Jack problem
Postby kdmay » 11 Jun 2010, 12:51
I've done a search and can't find the answer to my question, so I apologise if it is covered elsewhere.
I have built an SHO clone - love it! Does wonders for my clean channel.
Anyway, on to the problem. I am using a Switchcraft 712A DC Jack, as per below.
http://au.mouser.com/ProductDetail/Swit ... zU5g%3d%3d
I have the DC jack ground lug (centre pin) connected to the input jack shorting lug (the one that only grounds when a jack is connected to preserve battery life). I also have the negative battery teminal connected to the same DC jack ground lug.
I then have battery connected to one of the "live" DC jack lugs - the one that terminates the connection when you insert a DC plug. The other DC jack lug is connected to the circuit board.
Works fine with a battery. I tested the DC jack "floating" (i.e. not attached to the enclosure) and when I connected a DC plug (I made up a makeshift DC PS with a battery at the other end that tests 8.5v fine) the DC PS overrides the battery fine and powers up the board (i.e. LED on).
Problem occurs when I attach the DC jack to the enclosure and obviously ground the body of the jack. Now the DC plug does not work.
I tried reversing the "switching". That is, rather than have the insertion of the DC plug terminate the positive terminal of the battery, I had the grounding of the battery being terminated and the positive DC and battery always connected to the circuit board. Same problem occurs.
Help - this is driving me nuts......thankfully the SHO worked first time and sounds amazing. Maybe Mr Vex is watching over me and cursing my use of a DC jack.....!
kdmay
Re: DC Jack problem
Postby lolbou » 11 Jun 2010, 13:01
You need a plastic (i.e. insulated) DC jack... :slap:
A classic mistake indeed! I'll look for one of the already existing thread to merge your post (done!!)...
lolbou
Has thanked: 350 times
Have thanks: 240 times
Return to Power
