3PDT - should its function be on/on or on/mom?
What is the difference between the two?
- mysticwhiskey
Most pedals call for an on/off switch. The difference is that a momentary switch only switches on as long as you hold it down, and when you release it it switches off again. The on/off switch is latched which means it switches on when you press it and switches off when you press it again.
Thank you sir.
