millenium bypass "thud" sound
ballfire
Has thanked: 38 times
Post by ballfire »
good day..
i used a dpdt switch with millenium bypass LED indicator to my tonepad clone Boss DS-1.but the problem is when i engaged it "on"..theres a "thud" sound..!
i done some fixing solution..increasing the value of the input resistor going to the ground ..and changing the value increase the output resistor that goes to the ground..still the "thud" sound still there, when i bypassed it on.
how can i eliminate this?
thanks
