Behringer fs112v footswitch details required please.
All frequent questions on switching: true or not true bypass, transistor-based or mechanical.
Postby deltafred » 28 Nov 2012, 13:32
I recently scored a Behringer LX1-B Bass V-Amp cheap on fleabay but it doesn't have the 2 button FS112v (or FS112V-2) footswitch with it.
The footswitch has an attached cable with a 1/4" stereo jack (TSR).
Does anyone know how the footwsitch is wired internally (schematic) or have one they can post gutshots please.
I know it has a couple of momentary action switches and not much else so it is going to be pretty simple.
Thanks.
deltafred
Has thanked: 381 times
Have thanks: 259 times
Re: Behringer fs112v footswitch details required please.  Topic is solved
Postby FiveseveN » 28 Nov 2012, 19:18
I have one. Momentary microswitches indeed, with parallel debouncing caps IIRC. The DOWN button shorts tip to sleeve, the UP shorts ring to sleeve.
For this message the author FiveseveN has received thanks: 2
deltafred (28 Nov 2012, 20:09), modman (29 Nov 2012, 09:51)
FiveseveN
Has thanked: 127 times
Have thanks: 49 times
Postby deltafred » 28 Nov 2012, 20:11
FiveseveN wrote:I have one. Momentary microswitches indeed, with parallel debouncing caps IIRC. The DOWN button shorts tip to sleeve, the UP shorts ring to sleeve.
Thanks very much, just what I needed. :hug:
For this message the author deltafred has received thanks:
deltafred
Return to Switching & Wiring
