Need help with 3 channel Loop Selector wiring
Posted: 09 Mar 2013, 23:58
I want to wire up a 3 loop selector that will work like this:
Button 1 selects loop 1 (for now ill jumper it for clean bypass)
Button 2 selects loop 2 (plexi rythm pedal)
Button 3 selects loop 3 (rockbox clone set to singing sustaining lead)
Only one loop will be able to be selected at a time. I want to use it to mimic a three channel amp configuration. I'll put a dirt pedal on loops 2 and 3. I will jump loop 1 for as a clean channel(or utilize it later), 2 will be a pedal set to dirty rythm, and 3 will be a pedal set to singing lead overdrive.
The idea is to push one button to select the desired tone instead of doing the on/off dance dance revolution on the pedalboard mid-song.
I've built and boxed up a few pedals on vero board but I'm not great with switching schemes like this.
Thanks in advance,
Ken
Thanks in advance,
Ken
