Millenium Bypass "C" (4049)
All frequent questions on switching: true or not true bypass, transistor-based or mechanical.
maoriente
Post by maoriente »
I need some help, the LED stays on when the effect is bypassed.
I used this layout:
http://www.aronnelson.com/gallery/main. ... alNumber=3
and this hookup:
http://www.generalguitargadgets.com/pdf ... gi_mil.pdf
I used a 1k5 resistor for R1
Can't figure this one out.
Thanks,
Mike
maoriente
Post by maoriente »
Millenium Top
Millenium Top
I still can not find and shorts or opens. All offboard connections check out fine.
The LED stays on when bypassed.
What am I missing?
Offboard
Offboard
Stomp bottom
Stomp bottom
Millenium bottom
Millenium bottom
maoriente
Post by maoriente »
After struggling with this for a couple days, checking and rechecking my soldering and trying different resistor values I decided to take out the Millenium C and replace it with a Millenium 1 using a J201. Same problem, LED stays on.
So then I removed the stomp switch and wired the control of the Mill 1 directly to the output of the effect, same problem.
I remembered reading the effect needs to have a high DC resistance to ground for the Mill 1 to work, so I then connected the control of the Mill 1 to a 3 meg resistor to ground instead of the output of the effect and the LED goes out. Disconnect from the 3 Meg and the LED is back on. OMG!
I measure 12k from the effect output to ground, is this the problem???
The effect is a Wampler 57 clone.
http://elkit.web.id/wp-content/uploads/ ... ematic.jpg
maoriente
Post by maoriente »
Problem solved, solder bridge between 8th and 9th rails.
