Transistors??
Transistors??
Postby MuzzledAxe » 19 Jun 2012, 14:44
I have been building this,
http://tagboardeffects.blogspot.co.uk/2 ... mment-form
Yet I can't find the MPSA18 Transistors.I know there is some on the bay but there a bit pricey. Can anyone recommend a good alternative... In my stash I have MPS2907AG AND 2N2907A. ( I got both of these for this build after I realized I had the wrong ones with MPS2907AG). I also have 2n5088g.
Chhers
MuzzledAxe
Re: Transistors??
Postby Seiche » 19 Jun 2012, 19:21
You should check out a few datasheets. The MPSA18 has a hfe of 400-1500 according to it's datasheet. Maybe a 2n5089 would work well as it is between 400-1200.
Musikding sells the MPSA18 btw, and it's only 0.15€ a piece. They have 2n5089 as well @0.12€
Seiche
Has thanked: 264 times
Have thanks: 214 times
Re: Transistors??
Postby Westbury » 19 Jun 2012, 21:13
http://www.mammothelectronics.com/Searc ... rch=mpsa18
http://www.pedalpartsplus.com/mm5/merchant.mvc?
Also, keep in mind, the 2n2907 is PNP, not NPN. Devi uses the Tim Escobedo pushpull concept quite often.
Westbury
Have thanks: 7 times
Re: Transistors??
Postby MuzzledAxe » 19 Jun 2012, 22:26
Thanks all.
Whats HFE??? I am still learning about the flow of electrons...
Seiche..England where lucky tonight...the ball was across the line..
I am gonna buy both transistors and some header pins easy change them then..
Can I also ask what the Tim Escobedo pushpull concept is???
MuzzledAxe
Return to Absolute Beginners
Users browsing this forum: No registered users and 6 guests
