A Few Questions
A Few Questions
Postby aldaraia » 13 Sep 2012, 21:50
Howdy,
I'm just now getting in to designing and refining my own schematics and my first few ideas revolve around modifying a fuzz face schematic. I have a few ideas that I'd like to implement that I've "borrowed" from other pedals. The first that I'd like to implement are a feedback loop and starving voltage, both are ideas that I got from the Mountainking Frequency LSD. My questions are just about how one would implement these ideas.
For the feedback loop, I'm assuming that one would just take the output of the circuit and feed it back into the input of the circuit with, essentially, a volume pot controlling how much gets sent back to the input. I feel like this should work but I'm also concerned that sending the pot to ground would ground the output entirely and thus just act as a regular volume pot. If this is not so or there is another way to go about it, I'd sure appreciate input.
As for starving voltage, I assume that that could be done with a pot sent to ground between +9v and where it's expected in the circuit so you can reduce the voltage going to the circuit.
Please forgive any stupid talk, I have a basic and general understanding of how this stuff works, I do not know specifics, nor jargon. Any input would be appreciated.
aldaraia
Re: A Few Questions
Postby cdeschenes » 27 Sep 2012, 18:35
cdeschenes
Has thanked: 37 times
Have thanks: 20 times
Return to Absolute Beginners
