LM13700 both op amps in parallel?
Posted: 11 Feb 2013, 13:22
by johnnyg
Excuse me if this is a stupid question, I've a lot to learn (esp using ICs & not simpler transistors & valves). But I was looking at using the lm13700 in place of the ca3080 (to build a Ross/dyna comp unsuprisingly).
I was curious though if you could use both op amps in the 13700 in parallel in place of the ca3080. I've some idea of the use and benefits of valves in parallel. I was just curious if anyone had tried using a lm13700 in parallel... it feels a bit wasteful to only employ half of it.
Re: LM13700 both op amps in parallel?
Posted: 11 Feb 2013, 14:17
by grrrunge
How about a dual compressor? Use one half of the LM13700 for a ross and the other for a dyna-comp... That's what i'd do
Posted: 11 Feb 2013, 14:46
by johnnyg
That's a nice, simple idea that hadn't occurred to me, thanks
(If I had the lm13700 on its own board and connected to each circuit by flying leads I wouldn't even have to come up with a new layout)
Posted: 11 Feb 2013, 14:59
by frequencycentral
@ johnnyg - we are very much enjoying your avatar, tell us more about it.
Posted: 11 Feb 2013, 15:25
by johnnyg
Posted: 11 Feb 2013, 17:53
by Dirk_Hendrik
johnnyg wrote:Excuse me if this is a stupid question, I've a lot to learn (esp using ICs & not simpler transistors & valves). But I was looking at using the lm13700 in place of the ca3080 (to build a Ross/dyna comp unsuprisingly).
Do something with the other half. Stereo for the price of mono for example. Do not connect em parallel. Parallelling opamps is something some DIY-ers do because somewhere online someone claims superior sounds. Anyone with a decent engineering mind will understand a) it's bullshit and b) asking for trouble.
Posted: 11 Feb 2013, 22:02
by johnnyg
Thanks Dirk!
