Wah v846 build problems
Postby HHR18 » 09 Apr 2012, 12:20
I just finished my own Vox v486 using a Pigeon FX PCB but the wah doesn't seem to work. When I press down on the pedal I only get more treble and volume. It doesn't wah. I'm reading that this could be due to a an open inductor. The one I build has a Sabbadius inductor but my when using my old dunlop inductor (from a crybaby) I have the same problem. What else can be going on here? Any help would be greatly appreciated!
HHR18
Has thanked: 18 times
Have thanks: 3 times
Re: Wah v846 build problems
Postby CHEEZOR » 10 Apr 2012, 18:50
Check that electrolytic capacitor. If its not good or reversed polarity, then that could probably cause those problems.
CHEEZOR
Has thanked: 73 times
Have thanks: 91 times
Postby HHR18 » 02 May 2012, 17:46
Still haven't got it working. Here is a short audio clip showing my problem. First is the clean sound then I'm slowly turning the pot (by hand). The wah goes from very low volume to more trebly. I checked the inductor and it shows a resistance of about 25 ohms so that seem to be working. Any help would be greatly appreciated!
http://dl.dropbox.com/u/137602/sd.wav
HHR18
Postby HHR18 » 02 May 2012, 22:56
Here are some additional photos! I can't for the life of me figure out what's going on! Another strange thing is, is that one of the transistors has all pins with a voltage of about 8, while the other has normal voltages! Could this be a ground problem?
HHR18
Postby HHR18 » 03 May 2012, 14:02
SOLVED!! Had Q1 in the wrong pin configuration!
For this message the author HHR18 has received thanks:
telecaster (04 May 2012, 18:34)
HHR18
Postby CHEEZOR » 03 May 2012, 23:04
Thanks for posting the solution! This may help others in the future. :)
CHEEZOR
Return to Debugging
