Unsure about my Wiring
Postby fixxe » 10 May 2013, 15:09
Hello everyone!
I just completed a Maestro Wah Clone that unfortunately doesn't work. Bypass is working and I'm pretty sure I only wired it up wrong.
Now I'm not to sure about my "out" because it seems to be connected to "CW". Would that even work?
Could someone go over my wiring please?
fixxe
Re: Unsure about my Wiring
Postby Govmnt_Lacky » 10 May 2013, 15:17
Are you attempting to clone a Boomerang?
You do know that a Boomerang's pot is set up opposite of a normal wah pedal right?
If not a Boomerang, could you link to the schematic/project you are working from?
Govmnt_Lacky
Have thanks: 45 times
Postby fixxe » 10 May 2013, 15:33
I used this:
http://www.diyguitarist.com/PDF_Files/BoomerangPCB.pdf
But for the wiring I used two different layouts, and that's probably why I get no sound:
http://www.beavisaudio.com/techpages/StompboxWiring/
http://www.stewmac.com/freeinfo/i-1611/1611_dia1.gif
So I pretty much wired according to this last picture and that's why I dont have an "out" like the two other pictures.
fixxe
Postby fixxe » 12 May 2013, 18:32
Let me ask this way:
Is the switch-wiring right and the did I install the filter cap right?
fixxe
Postby fixxe » 12 May 2013, 23:54
new drawing
fixxe
Postby fixxe » 16 May 2013, 23:58
Problem solved, by the way :)
fixxe
Postby Greenmachine » 18 May 2013, 02:30
Just wanted to say that first drawing really made me smile. Thanks.
Greenmachine
Has thanked: 102 times
Have thanks: 19 times
Return to Debugging
