Tweak-O. pot behaviour
Postby BlackIvory » 05 Sep 2009, 18:39
Hi all.
Im new here and at the DIY field. I just finished building my first stompbox called the Tweak-O. which is a drive-booster/fuzz kinda thing.
but I'm having a problem with the drive pot.
Its a 250K pot. and the problem is that from about 7 o'clock to 2 O'clock theres no real change in the drive. but from 2 and upward theres a gain boost and volume drop.
what could be causing this? i'v gone over the wiring and everything 3 times and everything is as it should be.
all instructions and layout are here: http://www.smallbearelec.com/Projects/TweakO/TweakO.htm
heres a pic of mine's guts: http://up138.siz.co.il/up1/ozkzhvfgtwmm.jpg
Thanks for all who help!
BlackIvory
Re: Tweak-O. pot behaviour
Postby Greg » 15 Sep 2009, 07:29
Clip something and you'll get a volume drop compared to un-clipped, but you shouldn't get a volume drop when you increase the setting of the Drive pot in a circuit like this.
Changing the value of the pot will significantly change the level of Drive available.
Greg
Has thanked: 77 times
Have thanks: 195 times
Return to Debugging
