Powerboost Build Help: Low output on BYPASS?
Postby TheLemon » 02 Nov 2009, 21:01
I built an 18v Powered version of the Colorsound Powerboost (ala Gilmours) and power it currently with a 9v power supply, and it works fine except for a little un-biased sounding. The problem is when the pedal is off, the dry signal has low output, and sounds a little gritty and unclear. Any ideas what might be causing this? The switch maybe?
TheLemon
Have thanks: 21 times
Re: Powerboost Build Help: Low output on BYPASS?
Postby ansil » 17 Nov 2009, 05:00
did you use a dpdt or a tpdt for true bypass ??
ansil
Have thanks: 13 times
Return to Debugging
