Need help to debug Guvnor...
Postby bluesfaker » 12 Feb 2010, 21:59
Having searched for this many times, and not just all over this forum, I think I have an undocumented problem. :cry:
1) I am getting around 9v on all IC pins, dropping to 8.5 V on pins 2,3,6,7, using both a TL072CP and an LM1458.
2)When I use a power supply (standard boss thing, 9V, 200 ma), the pedal functions differently in a number of ways.
3) I am getting no sound in either bypassed or non bypassed settings, but a faint hum when using a power supply even though I am getting 9V on the board output and input.
I am completely flummoxed, have no idea how to troubleshoot past what I've done, and have verified the switch is working perfectly.
I would greatly appreciate any help with this. :scratch:
bluesfaker
Re: Need help to debug Guvnor...
Postby DrNomis » 13 Oct 2010, 13:28
The only IC pin that should have about 9Volts on it,should only be pin 8,here's a list of what should be on each IC pin:
Pin 1,4.5V
Pin 2,4.5V
Pin 3,4.5V
Pin 4,0V (Connected to circuit Ground)
Pin 5,4.5V
Pin 6,4.5V
Pin 7,4.5V
Pin 8,9.0V (Or thereabouts).
Hope that is of some help.... :)
The voltages you are getting indicate to me that something is shorting out somewhere,or the IC has had it.... :)
Has thanked: 123 times
Have thanks: 403 times
Return to Debugging
