Menatone - None More Black  [traced]
Re: Menatone None More Black [gut shots]
Postby bajaman » 21 Jul 2010, 22:25
Five DSG Jfets :wink:
J201 or possibly 2N5457/8/9 :?:
Jfet types and capacitor values or codes would be all that is required now to draw a schematic. :D
Has thanked: 438 times
Have thanks: 1506 times
Postby Belanger88 » 20 Aug 2016, 21:14
I just posted a schematic and gut shot of the 18v version which isn't the most common
Success is no accident. It is hard work, perseverance, learning, studying, sacrifice and most of all, love of what you are doing or learning to do.
Belanger88
Has thanked: 104 times
Have thanks: 33 times
Postby Belanger88 » 20 Aug 2016, 21:21
J202's are the fets actually
For this message the author Belanger88 has received thanks:
J0K3RX (20 Aug 2016, 22:24)
Belanger88
Postby Belanger88 » 22 Aug 2016, 03:12
Belanger88
Postby Belanger88 » 28 Aug 2016, 21:27
the NMB schematic has an error on it.. Jim discovered it a couple days ago when I was looking at the pics you sent and corrected it.. Was missing a 220k resistor to ground before the output buffer stage
ill post a new one asap
Belanger88
Postby Intripped » 28 Aug 2016, 22:54
thanks,
...please post a pic with higher resolution
Intripped
Has thanked: 580 times
Have thanks: 214 times
Postby J0K3RX » 29 Aug 2016, 21:51
Intripped wrote:thanks,
Try this.. Not "verified" I only traced it from the pics that Belanger88 sent me so, look it over and see if anything doesn't look right.
Big Thanks to Belanger88 for sharing your cool ass pedal! Also, for sending me the pics and getting some of the values that I couldn't see etc.. :thumbsup
This thing is a couple pots shy of a full tone stack... easy mod :wink:
For this message the author J0K3RX has received thanks:
Belanger88 (05 Oct 2016, 13:36)
J0K3RX
Has thanked: 320 times
Have thanks: 490 times
Postby Intripped » 29 Aug 2016, 22:41
thanks JOK3RX!
i've checked the schematic against your drawing of the circuit-layout, and i've found two errors:
- at the input, 68k and 1M resistors are swapped (should be 68k in series with the signal and 1M to ground);
- at Q4 - the 1uF capacitor that is connected to the source goes directly to ground, there's no 1K resistor in series with it.
I'm checking against the pics now
edit:
ok, i've checked the pics also, and spotted two other errors:
- there's a ceramic cap, connected to ground, after the 68k resistor (that is in series with the signal) at the input - can't read the value;
- at Q3 - the 1uF capacitor is in parallel with the 1.8k resistor, and not connected to 220k/22n/470k as in the schematic and drawing.
edit2:
i've mede a mistake as well about the resistors at the input:
1M resistor (connected to ground) is placed BEFORE the 68k resistor (in series with the signal)
so, 1M res is the pulldown res against switching noise
Intripped
Postby J0K3RX » 29 Aug 2016, 23:43
Intripped wrote:thanks JOK3RX!
edit:
Ok, the 68k and 1M resistors are corrected (I blame that on copy/paste and bad eyesight) :oops:
On Q4, I believe there is a 1k8 in series with the 1u cap.. See pic attached.
You got me on the ceramic cap on the input.. I can't fully see it in any of the pics I have, I can only see that it starts with a 1.. I would say that it's pretty safe to guess that it's either 100p or less likely 10p.
Still looking at the last one you posted.
J0K3RX
Postby Intripped » 29 Aug 2016, 23:51
on Q4 the 1Uf it's in parallel with that 1.8k resistor,
it's the source resistor (from what i can see at least)
Intripped
Postby J0K3RX » 30 Aug 2016, 00:04
Here's another angle on it..
You were right on the 1u cap on Q3 source... it is in series with the 1k8 resistor. :oops: kinda makes sense now :lol:
modman (02 Oct 2016, 19:18)
J0K3RX
Postby Intripped » 30 Aug 2016, 00:08
err... in PARALLEL with the resistor
Intripped
Postby J0K3RX » 30 Aug 2016, 04:38
Intripped wrote:err... in PARALLEL with the resistor
yeah, that's what I said derrr.. parallel :slap:
J0K3RX
Re: Menatone None More Black [gut shots]  [traced]
Postby J0K3RX » 30 Aug 2016, 06:15
Alright.. Check it :hmmm:
For this message the author J0K3RX has received thanks: 3
Intripped (30 Aug 2016, 09:51), Manfred (30 Aug 2016, 21:51), onebuzz (18 Sep 2016, 03:31)
J0K3RX
Postby Intripped » 30 Aug 2016, 09:51
looks ok to me
Intripped
Postby J0K3RX » 03 Sep 2016, 17:29
Kinda wondering about the 100k source resistor on Q5 ? Thinking something more like 10k to 22k may be a little better here?
J0K3RX
Postby onebuzz » 01 Oct 2016, 22:53
Built one up on double sided perf using JOK3RX's schematic. Turned out very well and runs off an 18 volt wall wart. Had to use SMD adapter boards for the J202's otherwise was a pretty smooth build and it sounds the business. Thanks JOK3RX for the nice PDF schem and lay-out.
For this message the author onebuzz has received thanks: 3
Belanger88 (05 Oct 2016, 13:38), J0K3RX (01 Oct 2016, 23:11), modman (02 Oct 2016, 19:19)
onebuzz
Has thanked: 65 times
Have thanks: 6 times
Postby J0K3RX » 02 Oct 2016, 19:50
onebuzz wrote:Built one up on double sided perf using JOK3RX's schematic. Turned out very well and runs off an 18 volt wall wart. Had to use SMD adapter boards for the J202's otherwise was a pretty smooth build and it sounds the business. Thanks JOK3RX for the nice PDF schem and lay-out.
Nice work onebuzz! You find any mistakes on the schematic? Can you record any samples?
Honestly, I had never even heard of this pedal until Belanger88 sent me a PM and asked me if I would like to help him trace it.. Of course I said "Hell Yes!" but he answered a lot of my questions, supplied pictures and most important of all he supplied the pedal! So, the "Thanks" should go to him for sharing this cool ass pedal!
I've not built it but, if or when I ever do I will probably stick a full adjustable tone stack in it because I like to have more knobs :lol:
J0K3RX
Re: Menatone - None More Black
Postby Belanger88 » 05 Oct 2016, 13:39
does anyone have a updated working schematic for this now? also let me know if you need any info and ill take more pics and upload them so we can get it 100% accurate... then mod the balls of it
onebuzz (09 Oct 2016, 20:32)
Belanger88
Postby Belanger88 » 05 Oct 2016, 13:45
all ceramic caps are 100pf FYI guys
Belanger88
Users browsing this forum: A1full, bastin, juice2, tinkercreek and 14 guests
