Krank - Distortus Maximus  [traced]
Re: Krank - Distortus Maximus
Postby Mr. G. » 25 Nov 2008, 03:24
I just built the pedal using >this< layout, but I must have done something wrong. The guitar sound doesn't come through, and when the gain is turned up past 12 it starts to oscillate very badly (think fuzz factory). I made a few changes, based on the parts I had, but I don't think they would do this. I checked the traces to make sure I didn't bridge anything together, checked the trace cuts, and made sure I added all the jumpers. Anybody got any ideas of what could be causing this, or where to start looking for the problem?
Here are the part substitutions that I made...
R2 - 429K (2 resistors in series)
R3 - 42K9 (2 resistors in series)
R4 - 2.2M
Bass pot - 500K
Volume pot - 500K
Dp and Rled were omited
Mr. G.
Have thanks: 8 times
Postby Torchy » 25 Nov 2008, 10:42
Trace cut was missing between tranny base and R8. Layout updated.
Torchy
Postby Mr. G. » 25 Nov 2008, 11:49
Thanks a lot!
I also noticed that the Mid pot is wired a little differently than some of the other layouts I've seen. On other layouts I've seen, Bass 1 goes to Mid 3, and Mid 2 goes to C9. Where in your layout, Mid 2 & 3 go to Bass 1, and then Bass 1 goes to C9. Am I just not understanding things, or will this have an effect on how the controls work?
edit: I just made the trace cut, and now it works. However, the tone controls don't seem to work right. The bass works fine, but the mid almost acts more like a treble control, and the treble pretty much does nothing at all. :scratch:
Mr. G.
Postby Torchy » 25 Nov 2008, 21:15
Oops - guess who photobucketed the wrong layout
Try now ... :oops:
Torchy
Postby Mr. G. » 25 Nov 2008, 22:31
That looks better! Thanks a lot Torchy!
I don't have any 1M pots, so I'll be using a 500K pot for the bass and level. How will this affect the sound compared to the 1M pots?
Noob question alert!!!! Is there a way to add a resistor in series with a pot to increase it's value?
Mr. G.
Postby earthtonesaudio » 26 Nov 2008, 00:19
If you add 500k in series with a 500k pot, it's like a 1M pot when it's up all the way. But if you want to turn it down all the way, there's still 500k of fixed resistance. So it's like a 1M pot that you can only turn halfway down.
earthtonesaudio
Has thanked: 17 times
Have thanks: 109 times
Postby Mr. G. » 26 Nov 2008, 00:24
I see. I figured it would be something like that, but wanted to make sure.
Mr. G.
Postby Torchy » 26 Nov 2008, 11:31
If you use the tonestack calculator, you can tailor the connected cap/resistors to get the same(ish) response with a 500k pot. You could actually customise the response of the whole eq section to suit your gear.
Torchy
Postby Mr. G. » 26 Nov 2008, 11:55
According to the TSC, a 500k bass pot won't have a huge affect on the tone. I'm more concerned about the affect of the 500k volume pot compared to the specified 1M pot.
I should probably just stop worrying about it, and finish the damn thing to find out for myself. :roll:
Mr. G.
Postby Torchy » 27 Nov 2008, 00:21
This schematic is from Musikding and has a buffer on the output, mind you I would have used a slightly different buffer ...
Torchy
Postby Mr. G. » 27 Nov 2008, 03:05
Would the buffer be needed, or redundant if I was already using a buffer pedal first in my chain?
Mr. G.
Postby turkey101 » 27 Nov 2008, 06:56
I've recently made one of these for a friend and it turned out great! A little too heavy for me, but there are some good sounds in there if you're willing to tweak. I added a switchable 500pF cappy over the volume pot to cut out some of the super highs.
My friend, however, would like more mids. I've messed about with the Tone Stack Calc for ages, but I can't see a simple way to boost the mids by themselves as the controls are so interactive. Or . . . am I missing something? Does anyone have any simple changes that will boost the mids a little more without having to completely re-design/re-build the circuit?
Thanks in advance,
turkey101
turkey101
Have thanks: 5 times
Postby soulsonic » 27 Nov 2008, 07:25
Changing the mid control to a higher value has the effect of more mids, but it will only get you so far because of the interaction. It's worth trying, cuz it's definitely something you can hear. If you have a 10K mid pot, try 25K; if it's 25K, try 50K. I think it can get good results as long as you don't overdo it, because if you go too high, I think you'll get the effect of all the controls doing mostly nothing.
Has thanked: 56 times
Have thanks: 274 times
Postby turkey101 » 27 Nov 2008, 11:35
Thanks for that suggestion - now, why didn't I think of that! I was too busy swapping cap and resistor values to think about the pots! I'll give it a try.
turkey101
turkey101
Postby Mr. G. » 28 Nov 2008, 17:51
Finally got the pedal finished, and it works fine now. Thanks again for updating the layout Torchy!
To me, there's a pretty narrow "sweet spot" in the gain, and the volume won't get up much past unity. The tone controls are very interactive, as stated before, but I'm a tweaker, so this isn't necessarily a bad thing. It's definitely got some nice tones in it, but I'm thinking I prefer my Crunchbox v2. It feels a bit more natural and amp like than the KDM. The KDM cleans up better with the guitars volume knob, though. I'm thinking a better tone control would be a big improvement. Possibly a Baxandall?
Mr. G.
Postby chris_d » 28 Nov 2008, 18:04
Mr. G. wrote:Finally got the pedal finished, and it works fine now. Thanks again for updating the layout Torchy!
As far as this schematic is actually correct (after hearing some better clips of the real thing i am starting to wonder if it is) there is a kind of narrow window of useable knob range on mine as well. I do however get a lot more than unity output on mine though.
The gain knob usually sounds best at something less than or equal to halfway, i usually leave the bass cranked open, and there is just a small window where the treble and mid can be adjusted not to sound trashy or muddy. I also find that the level sounds best at 75% or above, even though like i said, this puts it well above unity gain on my build.
I have built some other things since that i like a lot more for heavy distortion, but i still prefer this one to the crunch box i built. The crunch box is a lot of fun to play, just balls out like EVH-ish sounds, but the one i built is pretty much totally useless for anything but that. The Krank copy, on the other hand, i can get all kinds of useable mid gain sounds out of, and the ability to clean up with the guitar volume knob, is really a must for the way i play.
-chris
chris_d
Have thanks: 3 times
Postby Mr. G. » 29 Nov 2008, 17:48
Apart from the volume, I'm finding pretty much the same thing with the gain and tone controls. I also found that it sounds really nasty with a Boss DD-3 and CH-1 after it (just because of their buffers). They add a very shrill, ice pickey, high end to it. I've only noticed them do that with this one pedal.
What other high gain distortions would you suggest, that would compliment a Crunchbox? I like using the crunchbox for the more classic and midrange heavy rock/hard rock. For metal, I boost it with a YATS(Deaj).
Mr. G.
Postby biglouis » 06 Jun 2009, 20:04
Hi guys, i have a layout of the Krank Distortus Maximus, made by myself...
i hope you'll like it
(i'm from Brazil, so, sorry about my english)
biglouis
Postby SPeter » 06 Jun 2009, 20:17
Thanks! Good job! :applause:
Is it verified? :)
SPeter
Have thanks: 76 times
Postby biglouis » 06 Jun 2009, 20:24
The pads 1 and 2 must be conected with a wire
And Yes, it's verified!!!
Thank's
:wink:
biglouis
Users browsing this forum: No registered users and 12 guests
