Catalinbread Manx Loaghtan [guts]
Postby mmolteratx » 03 May 2011, 02:25
Here are some quick shots; I know they're crappy. I'll upload larger ones with those pesky pots removed later this week when I get some more time. I'll also add resistor/cap values to them.
http://s378.photobucket.com/albums/oo22 ... ratx/Manx/
For this message the author mmolteratx has received thanks: 7
azrael (03 May 2011, 19:32), batteryacidtea (03 May 2011, 02:41), culturejam (03 May 2011, 03:53), jwpartain1 (03 May 2011, 18:03), Nocentelli (03 May 2011, 06:27), RnFR (04 May 2011, 00:14), tp801 (03 May 2011, 12:32)
mmolteratx
Has thanked: 103 times
Have thanks: 623 times
Re: Catalinbread Manx Loaghtan [guts]
Postby freq67 » 03 May 2011, 16:16
God I hate that grounding technique. :evil: :roll:
freq67
Have thanks: 8 times
Postby jwpartain1 » 03 May 2011, 17:58
freq67 wrote:God I hate that grounding technique. :evil: :roll:
I think that while the technique Catalinbread uses to ground is certainly not the best method, we can all agree that it would be really nice not to have to do any soldering while the board is in the box. I'm pretty sure that's the thinking behind it, to minimize build time and therefore costs.
They're smart guys! I definitely wouldn't have thought to use a spring. That being said, I'm really interested in comparing this to Blackout Effector's Musket fuzz. Catalinbread, in my opinion, is top-class, with Blackout a close second in terms of build quality:cost.
Thank you for the pictures mmolteratx!
jwpartain1
Has thanked: 58 times
Have thanks: 57 times
Postby azrael » 03 May 2011, 19:32
Why? I don't see anything inherently wrong with it.
It allows for board mounted isolated jacks. Quicker construction for Cattybread.
azrael
Has thanked: 33 times
Have thanks: 93 times
Postby culturejam » 03 May 2011, 21:02
I actually think the spring is cool.
culturejam
Has thanked: 461 times
Have thanks: 575 times
Postby mmolteratx » 03 May 2011, 21:24
Pots removed and better pics:
I'll add component values later. Q4 is a 2n5457, Q1 and Q2 are 2n5088, Q3 and Q5 are Fairchild 2n2222A. Diodes are standard 1n4148. Yellow lines are top traces, orange are bottom traces, the blue line represents a resistor you can't see in the photo.
For this message the author mmolteratx has received thanks: 3
culturejam (04 May 2011, 00:30), lolbou (03 May 2011, 22:25), tp801 (04 May 2011, 20:40)
mmolteratx
Postby azrael » 03 May 2011, 21:30
Q5? Do they have an active Baxandall in there?
azrael
Postby deltafred » 03 May 2011, 21:32
It is a neat idea, I used a spring when I built my SFT, I put a smear of grease on the case where the spring touches it to prevent any corrosion forming.
You are only earthing the case for shielding purposes.
deltafred
Has thanked: 366 times
Have thanks: 254 times
Postby Ice-9 » 03 May 2011, 21:38
Great pics, I'm sure this one can be traced from these without to much trouble. Aftter a very quick glance over the overlay photo, the tone section looks like it might be based on a baxandall type. I will have a closer look at the photos later.
I take it the components that have no yellow or other colour lines marked over then al go to ground ?
Ice-9
Has thanked: 137 times
Have thanks: 356 times
Postby mmolteratx » 03 May 2011, 21:40
Yup. The one's that don't go anywhere are to ground. I've gotten to the tone control and so far it's pretty standard Muff. I'm guessing the tone stack is an active Baxandall. I'll finish work on it later tonight. This should be a quick trace.
mmolteratx
Postby Ice-9 » 03 May 2011, 21:47
mmolteratx wrote:Yup. The one's that don't go anywhere are to ground. I've gotten to the tone control and so far it's pretty standard Muff. I'm guessing the tone stack is an active Baxandall. I'll finish work on it later tonight. This should be a quick trace.
Had a little look closer at the tone and it looks less like baxandall type and moreof a standard 2 pot marshall/fender style. It looks a bit mixed up the way I have drawn it out at the moment. I will try and get a clearer drawing.
Ice-9
Postby mmolteratx » 03 May 2011, 21:55
Ya, it looks a lot like a Brownface type tonestack to me.
mmolteratx
Postby Ice-9 » 03 May 2011, 22:06
mmolteratx wrote:Ya, it looks a lot like a Brownface type tonestack to me.
Yeah , it's getting closer. The tonestack is very similar to the Fender 6G8 tone stack blonde twin with a slight diffeence.
http://amps.zugster.net/articles/tone-stacks
Ice-9
Postby Ice-9 » 03 May 2011, 22:14
I'm thinking it's Baxandall now, can you check that there is a connection between the two caps that connect to each end of the bass pot . (you have one going to the centre of the pot but the other cap doesn't if i follow the yellow lines) I think this cap must also go to the centre connection of the pot as well. If so then we have a baxandall for sure.
Ice-9
Postby mmolteratx » 03 May 2011, 23:00
They connect. I missed that trace.
mmolteratx
Postby mmolteratx » 03 May 2011, 23:03
It's definitely a Bax.
mmolteratx
Postby mmolteratx » 03 May 2011, 23:40
Mostly done. I can't seem to find the emitter or collector resistors for Q1, though the rest is finished. I'll start drawing it up on the PC in a minute. It's basically a Muff with the tone control replaced by a Baxandall stack and a source follower after the stack. I'm going to remove the jacks to see where these traces coming off of the collector and emitter of Q1 are going.
mmolteratx
Postby mmolteratx » 03 May 2011, 23:59
Tricky bastards. Full schem will be up tonight.
flatcrabs (04 May 2011, 00:07)
mmolteratx
Postby freq67 » 04 May 2011, 00:01
The reason I hate that ground is because of the oxidation, corrosion issue.Grounds should ALWAYS be connected either mechanically(nut ,bolt and star washer) or by solder. Just because something looks slick or cool means it's worth a shit. I think it's lazy and any builder of any electronic equipment would call it what it is ....bullshit.
freq67
Postby mmolteratx » 04 May 2011, 03:02
Done. See the notes.
Mod edit: schematic removed because of error
mmolteratx
Next
Users browsing this forum: Aleksei, mags05, take_scarlet, vot and 4 guests
