Earthquaker Devices Chrysalis Overdrive  [traced]
Postby ieatyouforbreakfast » 05 Jul 2011, 06:52
GUTS!
Capacitors from left to right:
First Row:
.1uf
.022uf
100pf
.1uf
Second row:
.001uf
100uf
4.7uf
.0047uf
.1uf
Transistors:
MPSA18
The overdrive sounds great, reasonably priced, and well built. Would love to figure out what goes on in this one!
Reason: Attached photos (so they don't go missing later)
For this message the author ieatyouforbreakfast has received thanks: 7
culturejam (05 Jul 2011, 13:56), joeboo88 (05 Jul 2011, 18:19), mcaviel (05 Jul 2011, 22:44), modman (17 Jul 2017, 16:26), RnFR (05 Jul 2011, 10:29), rocklander (05 Jul 2011, 06:55), tp801 (05 Jul 2011, 12:25)
ieatyouforbreakfast
Have thanks: 10 times
Re: Earthquaker Devices Chrysalis Overdrive
Postby jamiefbolton » 05 Jul 2011, 07:19
pics of the trace side?
jamiefbolton
Postby culturejam » 05 Jul 2011, 13:59
I like that layout!
It *almost* has a Jack Deville quality to it. 8)
culturejam
Has thanked: 460 times
Have thanks: 570 times
Postby ieatyouforbreakfast » 05 Jul 2011, 17:45
I'll try and get some trace side pics around Wednesday. It's on my practice board right now but I should be free to take it off and open it up sometime later this week.
ieatyouforbreakfast
Postby JOHNO » 05 Jul 2011, 17:52
It's going to be difficult to see much with the pots soldered on like that, unless your prepared to remove them. You might be able to bend them slightly to expose the traces.
Thanks for the pic.
JOHNO
Has thanked: 52 times
Have thanks: 62 times
Postby Lawnchair » 05 Jul 2011, 18:05
Looks pretty straight forward. MPSA18's are a interesting choice for a overdrive.
Lawnchair
Have thanks: 16 times
Postby ieatyouforbreakfast » 05 Jul 2011, 19:53
Lawnchair wrote:Looks pretty straight forward. MPSA18's are a interesting choice for a overdrive.
High gain transistors in an overdrive remind me of this.
I wouldn't say it's too far off from Martin's Folk Driver in basic design. It definitely does have that "chewy" discrete sound.
ieatyouforbreakfast
Postby RnFR » 06 Jul 2011, 11:12
the fact that the folk driver uses nfb as well as pfb makes it pretty unique. I wouldn't be surprised it was more along the lines of this-
viewtopic.php?f=7&t=12875
most likely two BJT stages and assym clipping, or possibly with the clipping in between the stages by the way it looks laid out.
Has thanked: 150 times
Have thanks: 173 times
Postby Mich P » 25 Oct 2011, 08:31
Any updates about this one ?
Thanks,
Mich P.
Mich P
Has thanked: 59 times
Postby reaganomics » 27 Apr 2012, 17:43
so this was discontinued earlier this month. Maybe now's a good time to get a hold of this schematic?
reaganomics
Postby black_out » 23 May 2013, 22:26
Any chance we can revive this one? Anyone out there that would care to trace the circuit? T'would be much appreciated.
black_out
Postby Mich P » 18 Jul 2013, 17:47
Still interested, if anyone ...
Mich P.
Mich P
Postby Mich P » 25 Sep 2014, 18:20
Anyone ?
Thanks,
Mich P.
Mich P
Postby MoonWatcher » 28 Sep 2014, 17:47
Mich P wrote:Anyone ?
Thanks,
Mich P.
In absence of replies, why not at least look at what is indicated on the pcb? I don't see any resistors of value 2m2 (red/red/black/green), so it's probably not built up from either an Electra or the Folk Driver. The caps look like they'd all be similar in value, and there are enough to indicate that they are needed for something like a Big Muff-type of sustain control. The b100k seems to reinforce this. For something adjusting gain off the emitter, you'd see either a 1k or 2k pot, or maybe a 10k pot, biggest.
So probably most caps are value of 100n, maybe with 22n or so. There's a diff cap type next to the clipping diodes - probably parallel to it, and probably a value Earthquaker didn't stock in the Panasonic-types. So maybe has a value of 1n or 2n2 - again very common if taking clipping diodes to ground off the collector of q2.
50kb pot - probably tone control either of a Big Muff-type, or maybe just a variation of stupidly wonderful tone control.
Resistor values seem to be standard things with transistors used like with a Big Muff or LPB-1 - I think I see 100r's, 470k, maybe 220r and similar. Also 1k and such, unless I'm just not making out a 3rd or 4th band correctly...
MoonWatcher
Has thanked: 42 times
Have thanks: 63 times
Re: Earthquaker Devices Chrysalis Overdrive  [traced]
Postby Manfred » 08 Jul 2017, 21:36
I bought a second hand one and traced it.
It was hard to trace the circuit because it is an multilayer PCB.
The ground connections and some others are on internal layers.
I traced the clipping diodes,a comparison of the reference diodes traces gives BAT48.
The the semiconductor analyzer read HFE=784@5Milliamps for Q1 and HFE=HFE=736@5Milliamps for Q2.
For this message the author Manfred has received thanks: 12
d312a (08 Jul 2017, 22:13), deltafred (15 Jul 2017, 20:45), dv8r601 (10 Jul 2017, 17:01), Mich P (09 Jul 2017, 11:09), mirosol (10 Jul 2017, 12:39), modman (22 Jul 2017, 21:59), nexion777 (14 Jul 2017, 17:45), Nocentelli (09 Jul 2017, 22:05), storyboardist (10 Jul 2017, 17:59), whoisrobmay (09 Jul 2017, 16:36) and 2 more users
Manfred
Has thanked: 890 times
Have thanks: 394 times
Postby Manfred » 15 Jul 2017, 15:35
I designed a stripboard board for, but I haven't actually made use of it.
Print the PDF-files with the original size setting option.
chrsysalisSize.pdf
chrsysalisComponets.pdf
chrsysalisCuts.pdf
Schematic with added potentiometer connection designations:
For this message the author Manfred has received thanks: 3
bmxguitarsbmx (15 Jul 2017, 21:48), deltafred (15 Jul 2017, 20:46), nexion777 (15 Jul 2017, 23:30)
Manfred
Users browsing this forum: edrios, himers, marckosolo1, mojah63, radiogaga and 13 guests
