I would like to know also. I etched it but I am waiting for a parts shipment.Stazinish wrote:Is this layout verified?ringworm wrote:I've had to tweak the pcb, made it a little too tight for the 470n caps
Black Arts Toneworks - Pharaoh [traced]
Thanks for the confirmation. Im in LA this week but will be back on the bench on Monday. Cant wait.ringworm wrote:Yes, I've built it.
- my favorite amplifier: Dr Z Maz 18, Tone King Metropolitan
- Completed builds: Veroboard: Rangemaster /w Range pot, "69" fuzz face, Octavia with tone cap switch.
PCB: Madbean Wah, One Knob Fuzz.
Failures: Clean Octave Blend - Location: Los Angeles, Ca
- Been thanked: 2 times
I've etched the "horus2" version PCB, and noticed there is no mention of r26 in the bom, but it's listed on the layout with no value. Scanning the schematics, it appears to be a 470k. In case any one else builds this version.
so i've got mine up and running.... not quite as "sabbath-esque" as I have heard. nice and heavy, tho. thanks for the pcb layout.
I gotta try and get it a little darker without introducing too much mud.
Hello, does anyone have the horus2.pdf file? I can;t seem to find it here.
Ah ok so the horus1 is the final and working layout?
Thanks.
Thanks.
- Visualdistortion
Anyone saw the Supreme version?
I wanna make it
I wanna make it wit chu
(again and again and again)
French... sorry
French... sorry
- ringworm
From their description I'd guess it's a pot (something close to 390k) wired as a variable resistor on the input and that seems like it could be useful. The other control they explain clearly but I find it hard to see the point of having six types of diode available on a rotary switch for clipping, trying to imagine the kind of words someone might come up with to describe the differences; louder and quieter might cover it all.Visualdistortion wrote:Anyone saw the Supreme version?
- Visualdistortion
I've posted this, on another forum but I would see gutshots to see if It's what I've expected.
Official Description:
The Supreme has all of the sounds and abilities of the Standard and Primitive Pharaohs, but with some very useful additions and a bit of a twist.
In place of the hi/lo switch,the Supreme utilizes a variable pre input control to infinitely adjust the saturation of the front end of the circuit from 1 to 10. In Place of the 3 way diode selector, the Supreme utilizes a 6 way rotary switch to select from the Standard Pharaoh diode settings, plus an additional 3 setting not available on the previous Pharaohs. The Pharaoh supreme allows selection from the following diode settings: Germanium, Asymmetrical Germanium(standard Pharaoh), Silicon (standard Pharaoh), Mosfet,LED and Bypass (standard Pharaoh).
So for the pre pot, we need to swap the Lo/Hi Switch for a 500K pot I think or something else.
For the clip control, use rotary switch 2 poles, swap the clipping switch on the original pedal and put the diodes on the description below. Just the mosfet is undifined.
I wanna make it
French... sorry
French... sorry
- my favorite amplifier: Ampeg
- Completed builds: Veroboards builds:
Throbak Overdrive Boost
Wampler Ecstasy
Creepy Fingers Doomidrive
Black Arts Quantum Mystic
Roger Mayer Voodoo Bass
Idiot box Blowerbox
Hudson Sidecar
Pcb builds:
Fulltone 69 (GGG kit)
Russian Big Muff (Musikding kit)
EHX Bassballs (home etched using Topopiccione layout)
BJFE BBOD (home etched, thx FSB)
Triangle Muff (Guitar PCB board)
Deluxe Bass Fuzz (home etched,gausmarkov.net layout)
Clone Theory Chorus (Celeste pcb from lectric-fx)
Cornish G2 (home etch, layout thx FSB)
Shin-Ei FY-2 Ge version (home etched, own layout)
Klon (Aion Refractor pcb)
Mutron Phasor II (home etched, layout thx JohnK)
Sunny-T (pcb by guitar pcb)
Rocket Overdrive (pcb by Pepers' pedals)
Sonomatic Deluxe Tape Delay (pcb by Skidmark)
Black Arts Quantum Mystic (adapted storyboardist layout) - Location: Lausanne, Switzerland
- Has thanked: 36 times
- Been thanked: 110 times
I have a special Pharaoh named "custom deluxe". I asked Mark if he could build me on with more clipping option.ringworm wrote:From their description I'd guess it's a pot (something close to 390k) wired as a variable resistor on the input and that seems like it could be useful. The other control they explain clearly but I find it hard to see the point of having six types of diode available on a rotary switch for clipping, trying to imagine the kind of words someone might come up with to describe the differences; louder and quieter might cover it all.Visualdistortion wrote:Anyone saw the Supreme version?
It was this build that gave him ideas which led to the Supreme.
The Clipping Switch on the Pharaoh Deluxe:
LSTR style Silicon
Pharaoh style Silicon
Symmetrical Germanium (1n270)
Asymmetrical Germanium (1n34a)
LED
BYPASS
It does not have the Mosfet like The Supreme does.
I made a modified version of this. It's a great pedal but I didn't like the tone controll, so I use a Baxandall. Schematics and video:
- Anubis Schematic.pdf
- (17.02 KiB) Downloaded 256 times
- Visualdistortion
Few informations from someone that have an original supreme Pharaoh
Red caps are actually 474
103 and 223 for the other ones
(caps are the same than the standard version)
A100K on the volume pot
A100K on the fuzz pot
B500K on the pre pot
Seems the Tone pot it's A100K too (4C4 written on top), just need the value of high, but certainly B25K.
Mosfet
Q5: BC20 2N 7000
Q6: BD48 2N 7000
Mosfet
Q5: BC20 2N 7000
Q6: BD48 2N 7000
I wanna make it
French... sorry
French... sorry
- zedsnotdead
Can you check the value of input resistor for Surpreme? If it has one?
I know it has a 500K pot for pre, but I was wondering what happens when the pot is @ 0 Ohms.... woudn't that be a too much input signal?
hi guys!, this is my layout for the Pharaoh Supreme version.
Pots and rotary switch are pcb mounted, component side, it's really thight but it fits in 125B box perfectly...MINI Supreme
PCB file and template for the box are already scaled so print as is.
i hope you enjoy whit this build, mine sounds really well!
ciao!
https://www.dropbox.com/s/nsrsz5p7gbojc ... l.pdf?dl=0
ciao!
- f0da856e-2ac3-4255-8468-0ad7e9f2d398.jpeg (28.23 KiB) Viewed 4518 times
- 713415f1-be57-47ee-a120-676de58ebfed.jpeg (32.3 KiB) Viewed 4518 times
- e1e17034-e326-4398-8a1b-56bce480447e.jpeg (25.83 KiB) Viewed 4518 times
- a26036a5-aa2c-4b42-8af5-f8ab414120a4.jpeg (27.2 KiB) Viewed 4518 times
ah, the layout
and the BOM:
RESISTORS
2m x 1 pulldown
100k x 4 - r4,9,16,19
470k x 5 - r2,8,14,20,26
10k x 4 - r3,10,15,18
1k x 2 - r5,6
6k2 x 2 - r7,13
100r x 2 - r11,17
2k2 x 1 - r22
100r DC filter
CAPS
10uf x 2 - c2,12
500pf x 3 - c3,6,10
470nf x 6 - c4,5,7,9,11,15
10nf x 1 - c8
22nf x 1 - c16
100nf DC filter
220uf DC filter
DIODES
d6,9 - 1n914
clipping section: socket and do your best choise
TRANSISTORS
1 X MPSA18
3 X 2N5089
POTS
VOLUME - A100K
SUSTAIN - A100K
HIGHS - B25K
TONE - B250K
PRE GAIN - B500K
rotary switch 2P6T
and the BOM:
RESISTORS
2m x 1 pulldown
1k x 2 - r5,6
6k2 x 2 - r7,13
100r x 2 - r11,17
2k2 x 1 - r22
100r DC filter
CAPS
10uf x 2 - c2,12
500pf x 3 - c3,6,10
10nf x 1 - c8
22nf x 1 - c16
100nf DC filter
220uf DC filter
DIODES
d6,9 - 1n914
TRANSISTORS
1 X MPSA18
3 X 2N5089
POTS
VOLUME - A100K
SUSTAIN - A100K
HIGHS - B25K
TONE - B250K
PRE GAIN - B500K
rotary switch 2P6T
