Mr. Black Boost Tiger  [traced]
Postby mmolteratx » 20 Mar 2013, 06:10
Traced from prototype #1/9. Jack has said that there are a few changes with the production model, but they're mostly with the PCB itself.
For this message the author mmolteratx has received thanks: 10
beedotman (05 Apr 2013, 20:15), Bernardduur (20 Mar 2013, 10:26), Fredenando (21 Mar 2013, 12:49), Ice-9 (20 Mar 2013, 16:58), JOHNO (20 Mar 2013, 09:40), modman (20 Mar 2013, 17:27), Nocentelli (13 Apr 2013, 21:16), rocklander (20 Mar 2013, 07:04), roseblood11 (20 Mar 2013, 15:27), tp801 (21 Mar 2013, 17:39)
mmolteratx
Has thanked: 103 times
Have thanks: 626 times
Re: Mr. Black Boost Tiger
Postby Jack Deville » 20 Mar 2013, 07:28
:applause:
Pretty close.
I'm a "professional."
Buy my products and make me rich.
www.jackdeville.com
Jack Deville
Have thanks: 88 times
Postby Ice-9 » 20 Mar 2013, 17:04
After reading Jack's excellent article on True Bypass I am surprised to see a pull down resistor in there as well as the current limiting resistor. For any one interested in the article its over on his Mr Black site under the "Straight Jive" menu. A great read for anyone that has not yet read it. :applause:
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Postby Jack Deville » 20 Mar 2013, 17:17
Maybe you should think about why it might be there.
www.jackdeville.com
Jack Deville
Postby D-Day » 20 Mar 2013, 17:55
Played this one at the guitar show down in Kent. Fantastic boost!
D-Day
Mojo Book Buster
Has thanked: 109 times
Have thanks: 23 times
Postby marshmellow » 20 Mar 2013, 18:02
Ole Jack sure has come a long way since then :roll:.
marshmellow
Have thanks: 122 times
Postby Jack Deville » 20 Mar 2013, 18:10
Boost Tiger is a fantastic clean booster / pre-amp.
Currently in production: Rev B1.
Now you have a clean, complete schematic. Build one for yourself and rock.
:hug:
www.jackdeville.com
For this message the author Jack Deville has received thanks: 12
D-Day (20 Mar 2013, 18:39), Fredenando (21 Mar 2013, 12:51), Ice-9 (20 Mar 2013, 18:58), IvIark (20 Mar 2013, 18:11), JOHNO (20 Mar 2013, 18:50), jonasx26 (21 Mar 2013, 11:14), mmolteratx (21 Mar 2013, 01:58), p.eat (21 Mar 2013, 09:20), rocklander (20 Mar 2013, 20:19), tp801 (21 Mar 2013, 17:40) and 2 more users
Jack Deville
Postby Jack Deville » 20 Mar 2013, 18:13
marshmellow wrote:Ole Jack sure has come a long way since then :roll:.
Quite a different circuit, although kudos! There are opamps in both.
www.jackdeville.com
Jack Deville
Postby D-Day » 20 Mar 2013, 18:13
Hay Jack! What's with that Devo hat lookin 123 gnd thingy?
D-Day
Mojo Book Buster
Postby Jack Deville » 20 Mar 2013, 18:16
D-Day wrote:Hay Jack! What's with that Devo hat lookin 123 gnd thingy?
My tribute to a great band.
www.jackdeville.com
Jack Deville
Postby D-Day » 20 Mar 2013, 18:18
:block:
D-Day
Mojo Book Buster
Postby mmolteratx » 20 Mar 2013, 18:26
It's the little grounding tab. Love those things. Keystone 629, IIRC. Got a bunch of them to use in my pedals.
mmolteratx
Postby marshmellow » 20 Mar 2013, 18:29
I see, you now vary the feedback resistor, those three years of research have been well spent. And you finally did take my advice regarding the bias buffering, my hat's off to you :lol:. Or does the ingenuity lie in the split resistor arrangement on the input and output?
marshmellow
Postby Jack Deville » 20 Mar 2013, 18:34
You got a bone to pick? Go buy a roast chicken.
Upset for some reason? Perhaps you should take some time to reflect on your life. I don't have time for you.
www.jackdeville.com
Jack Deville
Postby Ice-9 » 20 Mar 2013, 18:39
Jack Deville wrote:Maybe you should think about why it might be there.
I can't see how the 3PDT is wired up in the picture so maybe you not using that bypass system on this pedal ? or switch bounce is still causing a little pop without s pulldown resistor there ? I need enlightened. :popcorn:
Edited after noticing the post above , I just seen you posted the official schem with the switch in so it is that input grounding type series current resistor bypass typo thing. Thanks for showing us all that.
Extra - I managed to get a tunnelworm imported from USA last week. sounds great.
Ice-9
Postby skywise » 20 Mar 2013, 21:17
To keep input impedance lower than the max possible from the op amp?
skywise
Has thanked: 47 times
Have thanks: 20 times
Postby Ice-9 » 20 Mar 2013, 22:04
I did consider that it was about input impedance, but I would have thought the 470K resistor going to VBias does that job anyway.
Ice-9
Postby marshmellow » 21 Mar 2013, 02:57
Jack Deville wrote:You got a bone to pick? Go buy a roast chicken.
Yeah, maybe better spend your time studying a book on electronics every once in a while instead, because what I had to read on your tech blog (or whatever you want to call it) today is rather alarming. For naming yourself the "effects wizard" you seem to be remarkably ignorant concerning some basic principles. Like the distinction between current and voltage, for instance. You use the terms practically synonymously and throw them around like there is no tomorrow. And so on...
marshmellow
Postby bufferz » 04 Apr 2013, 15:01
Can someone help explain the reason for the 1k resistors at the input and output, just seems unique to me and would like to learn.
Also, I do not have any 56k resistors, can someone explain what they are doing in this circuit, are they just voltage dividers?
bufferz
Postby jymaze » 04 Apr 2013, 20:02
Output 1k resistor: limit current in case of short-cut at the output and lowers pop sound
Input 1k resistor: lowers pop-sound
You can use 47k or 68k for the voltage divider (you wrote 56k resistors, but you meant 51k, right?)
jymaze
Has thanked: 87 times
Have thanks: 160 times
Next
Users browsing this forum: vbhv and 11 guests
