Page 1 of 2
Mr. Black Boost Tiger [traced]
Posted: 20 Mar 2013, 05:10
by mmolteratx
Re: Mr. Black Boost Tiger
Posted: 20 Mar 2013, 06:28
by Jack Deville
Pretty close.
Posted: 20 Mar 2013, 16:04
by Ice-9
After reading Jack's excellent article on True Bypass I am surprised to see a pull down resistor in there as well as the current limiting resistor. For any one interested in the article its over on his Mr Black site under the "Straight Jive" menu. A great read for anyone that has not yet read it.
Posted: 20 Mar 2013, 16:17
by Jack Deville
Maybe you should think about why it might be there.
Posted: 20 Mar 2013, 16:55
by D-Day
Played this one at the guitar show down in Kent. Fantastic boost!
Posted: 20 Mar 2013, 17:02
by marshmellow
Ole Jack sure has come a long way
since then .
Posted: 20 Mar 2013, 17:10
by Jack Deville
Boost Tiger is a fantastic clean booster / pre-amp.
Currently in production: Rev B1.
Now you have a clean, complete schematic. Build one for yourself and rock.
Posted: 20 Mar 2013, 17:13
by Jack Deville
marshmellow wrote:Ole Jack sure has come a long way
since then .
Quite a different circuit, although kudos! There are opamps in both.
by D-Day
Hay Jack! What's with that Devo hat lookin 123 gnd thingy?
Posted: 20 Mar 2013, 17:16
by Jack Deville
D-Day wrote:Hay Jack! What's with that Devo hat lookin 123 gnd thingy?
My tribute to a great band.
Posted: 20 Mar 2013, 17:18
by D-Day
Posted: 20 Mar 2013, 17:26
by mmolteratx
It's the little grounding tab. Love those things. Keystone 629, IIRC. Got a bunch of them to use in my pedals.
Posted: 20 Mar 2013, 17:29
by marshmellow
Jack Deville wrote:marshmellow wrote:Ole Jack sure has come a long way
since then .
I see, you now vary the feedback resistor, those three years of research have been well spent. And you finally did take my advice regarding the bias buffering, my hat's off to you
. Or does the ingenuity lie in the split resistor arrangement on the input and output?
Posted: 20 Mar 2013, 17:34
by Jack Deville
You got a bone to pick? Go buy a roast chicken.
Upset for some reason? Perhaps you should take some time to reflect on your life. I don't have time for you.
Posted: 20 Mar 2013, 17:39
by Ice-9
Jack Deville wrote:Maybe you should think about why it might be there.
I can't see how the 3PDT is wired up in the picture so maybe you not using that bypass system on this pedal ? or switch bounce is still causing a little pop without s pulldown resistor there ? I need enlightened.
Edited after noticing the post above , I just seen you posted the official schem with the switch in so it is that input grounding type series current resistor bypass typo thing. Thanks for showing us all that.
Extra - I managed to get a tunnelworm imported from USA last week. sounds great.
Posted: 20 Mar 2013, 20:17
by skywise
To keep input impedance lower than the max possible from the op amp?
Posted: 20 Mar 2013, 21:04
by Ice-9
skywise wrote:Jack Deville wrote:Maybe you should think about why it might be there.
I did consider that it was about input impedance, but I would have thought the 470K resistor going to VBias does that job anyway.
Posted: 21 Mar 2013, 01:57
by marshmellow
Jack Deville wrote:You got a bone to pick? Go buy a roast chicken.
Yeah, maybe better spend your time studying a book on electronics every once in a while instead, because what I had to read on your tech blog (or whatever you want to call it) today is rather alarming. For naming yourself the "effects wizard" you seem to be remarkably ignorant concerning some basic principles. Like the distinction between current and voltage, for instance. You use the terms practically synonymously and throw them around like there is no tomorrow. And so on...
Posted: 04 Apr 2013, 14:01
by bufferz
Can someone help explain the reason for the 1k resistors at the input and output, just seems unique to me and would like to learn.
Also, I do not have any 56k resistors, can someone explain what they are doing in this circuit, are they just voltage dividers?
Cheers
Posted: 04 Apr 2013, 19:02
by jymaze
Output 1k resistor: limit current in case of short-cut at the output and lowers pop sound
Input 1k resistor: lowers pop-sound
You can use 47k or 68k for the voltage divider (you wrote 56k resistors, but you meant 51k, right?)
