Function f(x) Clusterfuzz  [traced]
Postby TV-Set » 24 Oct 2015, 00:35
Hello!
Anybody had a chance to get a hold of one of those? Or at least any ideas at what the circuit might resemble?
This fuzz box sounds massive!
Here's a PGS demo: https://www.youtube.com/watch?v=Qh7DyH21VKk
TV-Set
Has thanked: 25 times
Have thanks: 6 times
Re: Function f(x) Clusterfuzz
Postby Nocentelli » 25 Oct 2015, 08:47
It does sound good: Hopefully someone will get hold of one soon, and culturejam has stayed true to his principles:
culturejam wrote:Another thing I've frequently said I would do if I started a pedal business is ship a schematic with each pedal. :thumbsup
Lovepedal or the next guy to copy and under-cut is going to work out the circuit anyway. And it's nice to have a schematic on hand for repair or just general information. There's nothing that needs to be hidden. And there's nothing that can be hidden, so I see no reason not to include a schematic in the box.
viewtopic.php?f=6&t=14532&hilit=Schematic
mmolteratx wrote:absolutely zero commercial use allowed. If I find anyone selling these, I'll fly to your house and kick you in the nads. And you may or may not find yourself in trouble.
Nocentelli
Has thanked: 832 times
Have thanks: 826 times
Postby tabbycat » 25 Oct 2015, 10:10
thread at tgp http://www.thegearpage.net/board/index. ... x.1595793/
http://i1283.photobucket.com/albums/a55 ... g~original
they've also got one at stompboxclub if you are us based and want to borrow one for the weekend:
http://www.stomp.club/function-f-x--clusterfuzz.html
"be a good animal, true to your instincts" (d.h. lawrence).
"there is no excellent beauty that hath not some strangeness in the proportion" (francis bacon).
"ni dieu ni maître" (anarchist slogan).
For this message the author tabbycat has received thanks: 2
287m (25 Oct 2015, 11:54), modman (13 Jun 2016, 15:43)
tabbycat
Has thanked: 227 times
Have thanks: 63 times
Postby EBRAddict » 01 Nov 2015, 02:00
Any idea what those black connectors are on the 1/4" jacks, DC and footswitch wiring?
EBRAddict
Have thanks: 17 times
Postby TV-Set » 01 Nov 2015, 02:04
EBRAddict wrote:Any idea what those black connectors are on the 1/4" jacks, DC and footswitch wiring?
molex pcb connectors
TV-Set
Postby electrosonic » 01 Nov 2015, 05:36
Is that mictester's relay switching scheme in the lower left corner?
I see a spst, relay, 2 transistors, a small ignal diode, an electro cap and a couple of resistors.
Ie http://www.freestompboxes.org/viewtopic.php?f=13&t=13295
Andrew.
electrosonic
Has thanked: 28 times
Have thanks: 19 times
Postby Dc10 » 01 Feb 2016, 16:08
TV-Set wrote:Hello!
Premier Guitar does a fairly detailed review. I think it's 2 we'll known circuits cascaded. But that's just a wild guess.
Dc10
Postby skywise » 09 Jun 2016, 22:11
Dc10 wrote:Premier Guitar does a fairly detailed review. I think it's 2 we'll known circuits cascaded. But that's just a wild guess.
I heard it was a Klon. :horsey: :mrgreen:
skywise
Has thanked: 47 times
Postby skywise » 09 Jun 2016, 22:13
electrosonic wrote:Is that mictester's relay switching scheme in the lower left corner?
There is also a micro-controller. :secret:
skywise
Postby Dc10 » 11 Jun 2016, 02:09
Looks more like an EHX Soul Food to me
Dc10
Postby skywise » 23 Sep 2016, 05:43
Looks like an early prototype. Soldering on top is a bit messy but nothing really bad. :hmmm:
Still pretty sure it's a Klon clone. :horsey:
skywise
Postby Nocentelli » 21 Jan 2017, 18:55
HappyCat (21 Jan 2017, 23:42)
Nocentelli
Postby Nocentelli » 24 Jan 2017, 01:25
For this message the author Nocentelli has received thanks: 12
batteryacidtea (26 Jan 2017, 03:51), electrosonic (24 Jan 2017, 01:48), EmmG (24 Jan 2017, 17:50), Hirti (25 Jan 2017, 23:52), karul (24 Jan 2017, 17:59), Manfred (24 Jan 2017, 14:29), p.eat (24 Jan 2017, 11:24), roseblood11 (24 Jan 2017, 02:02), Stray (28 Jan 2017, 22:14), tp801 (24 Jan 2017, 20:54) and 2 more users
Nocentelli
Postby Nocentelli » 28 Jan 2017, 10:23
I ordered this pedal late last saturday afternoon, and it had arrived when i got back from work on monday. I played through it for 20 minutes or so, then popped the back off to have a go at tracing it. The molex connectors for in/out, power/ground and footswitch connections made it super easy to completely remove the pcb with zero risk of damage, and i then spent a couple of hours turning it over and over in my hands, peering at the traces and components through a magnifying glass to sketch out a schematic. Most traces are clearly visible, although they are tightly bunched at the top edge of the pcb by the pots, and some pass between the lugs of the filter switch.
All box caps values are clearly visible, but the electro's and ceramics are not all clear due to their positions. However, i found a photo on facebook of the parts stash used to build the pcbs, which made cross checking the parts values a little easier. For example, the big electro in the power line is likely to be 220u, and the ground cap at the input may be the 100p or 680p. The other parts that don't appear in my schematic are from the relay-based true bypass switching, which i didn't bother tracing. I tried to take some shots of the pcb, but artificial light and a crappy camera phone means they're not great and also too big to host here. Next time we get a decent bright day here in the UK (maybe April?), I'll try and convince my wife to take some decent pics with her fancy camera.
For this message the author Nocentelli has received thanks: 4
deltafred (30 Jan 2017, 14:24), nr372 (31 Jan 2017, 08:20), Stray (28 Jan 2017, 22:14), tp801 (28 Jan 2017, 11:13)
Nocentelli
Re: Function f(x) Clusterfuzz  [traced]
Postby Nocentelli » 30 Jan 2017, 00:58
For this message the author Nocentelli has received thanks: 14
Ask Nothing (09 Feb 2017, 19:07), culturejam (30 Jan 2017, 13:41), deltafred (30 Jan 2017, 14:24), FiveseveN (30 Jan 2017, 02:36), HappyCat (03 Feb 2017, 17:57), jalmonsalmon (24 Mar 2017, 17:22), Manfred (30 Jan 2017, 12:43), nr372 (31 Jan 2017, 08:29), tp801 (30 Jan 2017, 14:45), Zokk (30 Jan 2017, 11:15) and 4 more users
Nocentelli
Postby culturejam » 30 Jan 2017, 13:47
That looks correct, but I don't have the production schematic in front of me.
Nice work! :thumbsup Although it's constructed in a way that makes assembly/disassembly quite easy, and as I recall, all the traces are on one side, both of which make tracing a lot easier than, say, something from Death By Audio. ;)
Nothing hidden, no goop or that sort of tomfoolery. :horsey:
Hope you guys enjoy it. Brian, Dave, and I had a lot of fun designing it. :hug:
Note: there are a few
For this message the author culturejam has received thanks: 5
brejna (30 Jan 2017, 18:59), FiveseveN (30 Jan 2017, 21:20), HappyCat (03 Feb 2017, 17:57), Nocentelli (14 Feb 2017, 22:03), storyboardist (30 Jan 2017, 15:15)
culturejam
Has thanked: 460 times
Have thanks: 571 times
Postby culturejam » 30 Jan 2017, 13:50
So what did you think of the sound? I know that tone is far less important here than resistors, but I thought I'd ask. :mrgreen:
culturejam
Postby johnk » 05 Feb 2017, 20:52
i just finished building one today and i dig it.
here's the PCB layout that i drew up for it:
and here's the PCBs in a pdf file:
http://johnkvintageguitars.homestead.co ... z_PCBs.pdf
For this message the author johnk has received thanks: 7
287m (06 Feb 2017, 11:33), aishabag23 (06 Feb 2017, 16:24), Ask Nothing (09 Feb 2017, 19:07), deltafred (05 Feb 2017, 23:49), jalmonsalmon (25 Mar 2017, 04:23), Nocentelli (05 Feb 2017, 21:43), panchokunstmann (06 Feb 2017, 18:46)
johnk
Has thanked: 30 times
Have thanks: 257 times
Postby aishabag23 » 06 Feb 2017, 16:26
johnk wrote:i just finished building one today and i dig it.
Awesome, John! I like your PCB layouts. They etch beautifully. I'll have to give this one a go.
aishabag23
Has thanked: 86 times
Have thanks: 11 times
Postby johnk » 06 Feb 2017, 19:04
DONE!
For this message the author johnk has received thanks: 4
EmmG (09 Feb 2017, 08:59), Güero 2.0 (06 Feb 2017, 19:21), jalmonsalmon (24 Mar 2017, 17:22), Nocentelli (30 Mar 2018, 15:06)
johnk
Next
Users browsing this forum: Big_Mike, John G, MJC, oegoeh, ppyyff and 5 guests
