Zvex Fuzz Factory 7
Zvex Fuzz Factory 7
Postby k.kobain » 08 Aug 2016, 02:10
Does anyone have a schematic? :?:
k.kobain
Re: Zvex Fuzz Factory 7
Postby tube-exorcist » 08 Aug 2016, 09:01
Of course...... Zachary should have one.
For this message the author tube-exorcist has received thanks: 3
287m (09 Aug 2016, 22:55), juice2 (13 Aug 2016, 15:38), lolbou (08 Aug 2016, 22:05)
tube-exorcist
Has thanked: 210 times
Have thanks: 77 times
Postby theblackman » 12 Aug 2016, 06:26
get fuzz face, add knobs.
“Dream as if you'll live forever, live as if you'll die today.” James Dean
theblackman
Have thanks: 3 times
Postby xaxxop » 04 May 2018, 18:09
It’s a fuzz factory using 50s transistors, adding a passive tone control (I wonder if the tone control is like the woolly mammoth), a switch to bypass the tone control and and 9 position switch for the fat feature (I guess switching the original 10nF capacitor for 8 more differents values).
Is someone brave enough to draw a eschematic to start testing? :hmmm:
:horsey: I will try one tomorrow :scratch:
Leo
Leandro
xaxxop
Postby jrfox92 » 05 May 2018, 07:29
eatyourguitar probably has one. :popcorn:
eatyourguitar wrote:schematic:
[ Image ]
the switch should be DPDT ON-OFF-ON so you can go back to the stock fuzz factory. everything on here is designed so you can go back to the fuzz factory. I did not want to build something that could not replace my old 7 knob fuzz factory that I sold and ZVEX copied exactly 3 years ago. the output volume is doubled without adding noise from extra gain stages. the only thing I am a little unsure about are the values for C7 and C4. if you want to do the tone control like the official zvex 7 knob, you should leave tone pin1 disconnected or maybe just move the tone control to the output jack like a guitar. I am finishing up the pcb design right now if anyone is interested PM.
comments and suggestions welcome.
jrfox92
Have thanks: 52 times
Users browsing this forum: art7710, kryoz, laoliang and 14 guests
