Frostwave Funk-a-Duck.
Postby digi2t » 20 Oct 2016, 01:10
Hey all, long time no contribute. Sorry, been uber-busy. Anyway, here are the prelim pics;
I'm kind of wrapped up in two monster builds right now (Lab Series preamp and Son of Stormtide flanger), so I'll be slow to trace it. At first glance though, it does look like half of an MS-20 style filter section, with and envelope detector on the front end. I tried it, and it sounds pretty good, but I find that the envelope is rather picky when it comes to pick attack. You have to be fairly constant on the attack, or else it gets kind of hit or miss. I should have put The Engineers Thumb in front of this, it probably would have done a fine job of stabilizing things. Power section looks to be basically copy/paste of the Resonator. Straight forward +/-15v made from 16vac. Anywho, on with the show....
No matter how many times I cut it, it`s STILL too short!
For this message the author digi2t has received thanks: 2
Nocentelli (22 Oct 2016, 18:08), Zokk (08 Nov 2016, 13:45)
digi2t
Has thanked: 52 times
Have thanks: 343 times
Re: Frostwave Funk-a-Duck.
Postby digi2t » 08 Nov 2016, 12:34
Here's the prelim trace. Putting it into schematic form now.
For this message the author digi2t has received thanks: 6
allesz (08 Nov 2016, 18:14), lohstah (08 Nov 2016, 21:18), Manfred (09 Nov 2016, 01:13), Nocentelli (08 Nov 2016, 22:48), tp801 (09 Nov 2016, 11:58), Zokk (08 Nov 2016, 13:50)
digi2t
Postby caspercody » 08 Nov 2016, 20:20
What software did you use to:
lighten the background
Draw in wiring
caspercody
Has thanked: 29 times
Have thanks: 37 times
Postby digi2t » 09 Nov 2016, 00:41
Corel Paintshop Pro.
I take a hi-rez picture of both sides, flip the trace side image horizontally, and then superimpose one over the other as transparencies. I then adjust the transparency level of each, sometimes change the layer order if necessary, and play with colors, brightness, and contrast until I get a composite image that I can see the traces of both sides. Then it's just a matter of using the actual board, and drawing trace lines on the composite image.
digi2t
Postby toneman » 09 Nov 2016, 00:47
Very clever reverse engineering technique, digi2t :applause:
Look forward to seeing what U come up with for the schematic :wink:
Live Long and Solder 8)
Tone-to-the-Bone
toneman
Has thanked: 87 times
Have thanks: 19 times
Postby digi2t » 10 Nov 2016, 12:24
Here you go folks. Sorry about the messy layout, but I always sucked at laying out schematics. :roll:
The double 0 ohm resistors are there because they're on the board. The "Env out" and "Bypass" boxes are open pads on the board. I just drew it like I saw it, that includes the bypass switch setup, which is something that I've never seen before. If you see anything hinky, let me know and I'll check it out. If anyone wishes to clean this up, by all means...
karul (10 Nov 2016, 16:07), Manfred (10 Nov 2016, 23:21), marshmellow (07 Apr 2017, 14:13), toneman (11 Nov 2016, 00:14), tp801 (12 Nov 2016, 21:25), uncleboko (10 Nov 2016, 22:11)
digi2t
Users browsing this forum: kenny Treble, Pokfor and 29 guests
