Blackout Effectors Whetstone Phaser  [traced]
Postby Sogum92 » 03 Aug 2018, 11:18
Dear,
I trace out Blackout Effectors Whetstone Phaser
Sorry, It is no Schematic, Only Layout
I attacted Wiring image
It is working
Thanks.
For this message the author Sogum92 has received thanks: 8
destro (03 Aug 2018, 14:20), Intripped (10 Sep 2018, 21:32), modman (13 Sep 2018, 16:24), Moonsun (04 Aug 2018, 08:51), Nocentelli (03 Aug 2018, 15:23), ringworm (26 Aug 2018, 20:16), sixthfloor (04 Aug 2018, 08:08), tinker (29 Nov 2018, 16:08)
Sogum92
Have thanks: 10 times
Re: Blackout Effectors Whetstone Phaser
Postby pervyinthepark » 09 Sep 2018, 17:20
might get around to making my own schematic for this :P
pervyinthepark
Have thanks: 6 times
Postby DanAmpora » 10 Sep 2018, 17:48
Beat you to it. Still kindly check if I've missed something. :lol:
For this message the author DanAmpora has received thanks: 2
Intripped (10 Sep 2018, 21:37), Manfred (10 Sep 2018, 22:24)
DanAmpora
Have thanks: 22 times
Re: Blackout Effectors Whetstone Phaser  [traced]
Postby DanAmpora » 11 Sep 2018, 21:20
This should be the correct one now, I forgot the output capacitor :oops:
For this message the author DanAmpora has received thanks: 11
auden100 (15 Sep 2018, 09:17), AZX309 (13 Sep 2018, 16:44), DMgremlin (22 Sep 2018, 18:50), dv8r601 (20 Sep 2018, 01:15), Manfred (11 Sep 2018, 22:07), modman (13 Sep 2018, 16:24), Nick123 (12 Sep 2018, 14:59), Nocentelli (17 Sep 2018, 18:46), roseblood11 (11 Sep 2018, 22:48), tinker (29 Nov 2018, 16:08) and one more user
DanAmpora
Postby Sogum92 » 17 Sep 2018, 06:11
DanAmpora wrote:This should be the correct one now, I forgot the output capacitor :oops:
Thanks a lot :)
Sogum92
Postby mulekicker » 30 Sep 2018, 20:32
Anyone with a working build from this schematic? I made the vero Alex put up over at tagboardeffects but no luck. Could definitely be my error but I can't find any.
mulekicker
Postby Sogum92 » 02 Oct 2018, 03:45
mulekicker wrote:Anyone with a working build from this schematic? I made the vero Alex put up over at tagboardeffects but no luck. Could definitely be my error but I can't find any.
My Layout & Wiring is 100% Working.
I will check your vero layout
Sogum92
Postby mulekicker » 02 Oct 2018, 12:50
Awesome. Thank you!
mulekicker
Postby mulekicker » 03 Oct 2018, 05:17
BTW. Thanks to Alex and MAO over at tagboardeffects, the vero layout is verified. I fucked up one of the pins on a 13700, duh! Thank you so much for doing this one, it's super sweet.
For this message the author mulekicker has received thanks:
roseblood11 (03 Oct 2018, 08:43)
mulekicker
Postby Sogum92 » 03 Oct 2018, 18:57
mulekicker wrote:BTW. Thanks to Alex and MAO over at tagboardeffects, the vero layout is verified. I fucked up one of the pins on a 13700, duh! Thank you so much for doing this one, it's super sweet.
I see. Congratutation.
Original IC is NE5517N x 3
All TR is Fairchild.
Thanks.
Sogum92
Postby Sogum92 » 04 Oct 2018, 17:55
http://www.blackouteffectors.com/wp-con ... nual_1.pdf
The FIX setting kills the LFO completely.
In this setting the RATE knob will manually sweep through different points in the phasers sweep,
allowing for stuck-wah- like sounds, hollow telephone effects, and provides overall different approaches to tone shaping.
Sogum92
Users browsing this forum: art7710, esist and 11 guests
