Zvex - Box of Rock  [traced]
Postby B Tremblay » 09 Oct 2007, 23:35
We thought it was a good approach and it works well, if you accept its limitations and don't expect some sort of miracle tone from it. We wanted to expose others to it and then decided to pass the torch, rather than be viewed as one-trick ponies who'd jumped the shark (please forgive my animalistic cliches).
That being said (typed?), it's still a valuable building block, as you can see in the Thor.
B Tremblay
Have thanks: 17 times
Postby markm » 10 Oct 2007, 00:15
B Tremblay wrote:We thought it was a good approach and it works well, if you accept its limitations and don't expect some sort of miracle tone from it. We wanted to expose others to it and then decided to pass the torch, rather than be viewed as one-trick ponies who'd jumped the shark (please forgive my animalistic cliches).
I have to say you guys at ROG have certainly influenced some of the stuff I've tried to design myself :roll: and I have borrowed some of your ideas and implemented them in different ways as well.
Besides, I like doing layouts for your circuits!!
Would love to see a Compressor project from the ROG team! :D
markm
Have thanks: 8 times
Postby nokaster » 10 Oct 2007, 15:28
since markm and madbean posted a very nice layout each, i'm wondering which of both has the correct capacitor values for a "true" box of rock?
everything else seems to be about the same, but the caps are different on both layouts... confused...
(keep in mind i'm extremely new at this...) :oops:
nokaster
Postby madbean » 10 Oct 2007, 16:04
Looks like I labeled C6 and C7 in my layout as 22nf, and they should be 2nf according to the schem. I'd have to check my build to see what I actually used. Anyway, either will work....it will just shape the overall tone a little differently. You can socket those areas too and try out different values for R6/C6 and R13/C6 for different flavors of low pass filtering.
madbean
Postby pulpek » 18 Oct 2007, 13:34
I built the madbean´s layout.Great and so clean. It sounds GREAT, but a little "bug". The ""tone" pot is reverse wired, isn´t?
pulpek
Postby madbean » 18 Oct 2007, 16:06
Hmm, it isn't reversed on my build. You should be able to switch the wires on lugs 3 and 1 of the tone pot to fix that.
madbean
Postby Lexx » 06 Nov 2007, 02:32
Lexx
Postby madbean » 14 Nov 2007, 16:50
Apparently the Box of Metal is priced around $300. That should get a reversin' on principal.
The gate thing is neat, though.
madbean
Postby Lovepedal Detective » 14 Nov 2007, 17:35
The Box Of Metal will be surface mount. The boards are being done by Cusack.
LPD
Lovepedal Detective
Have thanks: 4 times
Postby Lovepedal Detective » 18 Nov 2007, 07:27
I'm having trouble with my BOR vero build. Can anyone give me the voltage readings of the transistors?
LPD
Lovepedal Detective
Postby Lovepedal Detective » 19 Nov 2007, 00:06
Worked on the Vero layout again today, and can't figure out why it isn't working. I get no signal at all. My voltages are very high on the transistors as well. I have an original in front of me and my voltages aren't even close to the real thing!
Has any built the vero layout? I may try the perf layout, but I really don't like working with perf.
LPD
Lovepedal Detective
Postby bajaman » 19 Nov 2007, 00:43
ps: make sure you connect the mosfets correctly - check your pinouts.
:wink:
Has thanked: 456 times
Have thanks: 1569 times
Postby kaufhaus » 29 Nov 2007, 14:46
just finished building the box of rock from the schematics posted here. it's does sound very close to the zvex examples, but is a bit noisy a higher gain settings. it's quite clear that this is matter of fact with overdrive pedals, but still a bit too much in this case.
anyone else experienced anything like this?
kaufhaus
Postby madbean » 29 Nov 2007, 16:09
Yes, mine definitely gets a bit noisy on the last quarter of the drive pot.
madbean
Postby kaufhaus » 29 Nov 2007, 20:10
ok, great, so it's not just my built! just found out about the 'crackle okay' feature. zacki really has a great sense of humor.
kaufhaus
Postby bajaman » 29 Nov 2007, 20:56
if you think selling a defective product and convincing people that you DESIGNED it that way is humorous, then you are a truly sad puppy :shock: :lol:
....and .....yes....mosfets are hisssssssy - but don't you know - Zacki designed them that way - the hiss is intentional and an inherent part of his design concept (whhoops - I am starting to sound like him :oops: :oops: )
Do yourself a favour - replace the mosfets with jfet mu amps - or better still - just build the BSIABII - you will be following in Zacki's footsteps :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
:wink: bajaman
Postby Lovepedal Detective » 11 Dec 2007, 05:12
Still can't get mine working. My problem seems to be with the first gain stage. My volume works and my tone works. The gain control isn't changing any voltages on the first BS170 like it's supposed to. Anyone have any ideas? I'm going off of the vero layout posted here.
LPD
Lovepedal Detective
Postby bajaman » 11 Dec 2007, 06:55
Hi LPD
1: Make sure you have a good mosfet - they are damaged very easily
2: Make sure you have the mosfet connected properly - check the pin out - download the data sheet - google it etc.
Good luck
Postby Lovepedal Detective » 12 Dec 2007, 03:48
FYI the Vero Layout posted on the first page is not correct. It will not work if you build it that way. I'll make a new vero based on that one with corrections.
I've got my pedal working now, and it sounds fantastic..... maybe even better than my real BOR.
LPD
Lovepedal Detective
Postby John Lyons » 12 Dec 2007, 03:55
I built the BOR from Beans PCB layout. I really like it.
Nice crunchy yet articulate sounds.
John
John Lyons
Have thanks: 26 times
Users browsing this forum: okgb, tsiksmith and 11 guests
