Xotic - RC Booster [traced]
Had to search around for that audio probe, but I'm going to make one and hope it helps with this one.
Thanks a lot! I really appreciate the help.
When everyone is against you, it means that you are absolutely wrong-- or absolutely right.
- joeboo88
Ebay is a fucker ~ Sinner - If this is something unique, then I'm a teletubbie ~also Sinner
Cool, thanks.
I found this one before you posted your link: http://www.diyguitarist.com/PDF_Files/D ... Tester.pdf
Going to run with that type of design so I'm not limited to the length of the cable such as I would with the setup at the link you posted.
Cheers!
*Edit: Didn't see that second option at your link... same idea.
Cheers!
- pedalgrinder
Has anyone ever wanted to add a mid range control to there RC booster Well oportunity knocks i have a found a circuit that will quite happily mod your RC booster without changing the original circuit all it will do is essentially add a mid range control to it. As far as i understand they have released a rc booster with a mid control but anyway here is a really cool mod enjoy!!!!!!!!!!!!
didn't work if monted on the Top side ?sevinisthenumber wrote:it works now. i just mounted the ic and transistors on the trace side....
Your layout it's verified? ? i realy love your software DIY layout creator, i download now
Here's one:Roast7 wrote:There are some vero layout verified?
I found this but do not know if it is verified
http://diy-layout.com/35
http://www.sabrotone.com/?p=3148
- aion
I traced a recent RC Booster since there are a few different schematics out there and I wanted a definitive trace.
The only real change from earlier schematics is that the input capacitor C7 is 1uF instead of 47n. No real difference in tone since the cutoff frequency is really low either way. Still, good to have confirmation that the RC Booster hasn't changed much and the previous traces are accurate.
Full tracing journal here (includes AC Booster and Bass RC circuits as well):
https://aionelectronics.com/blog/tracin ... c-booster/
Malacandra PCB here (can build any of the three variants) - updated to V2 based on traces:
https://aionelectronics.com/project/mal ... c-booster/
Hi, has anybody checked out Version 2 with that additional Gain2?
Is that "added gain channel" just a second pot on a switch, replacing Gain 1 or maybe something else? The manual states "when switch is active gain 2 is added to gain 1". A schematic would be highly appreciated.
