Ashbass - FUZZbrite
- analogguru
Maybe you won´t believe it, but "ashbass" himself is bidding on this Mosrite Fuzzrite:
https://cgi.ebay.com/1960s-Mosrite-of-C ... dZViewItem
I thought he is the only one already with the secret recipe...? Does he need to update his secret schematic ? Hmmm.... For this he doesn´t need to buy this unit, he only has to visit the sellers homepage:
http://www.reinmoser.com/Mosrite.htm
As you can see there, it is the second version (ungooped) Fuzzrite with 4 x 470k and two TZ82.
- soulsonic
Heh, maybe he collects them.
Hi. I've been looking around the web for Fuzzrite info and I found a pic that Ashbass had posted at the TGP forum of the ungooped guts of his Fuzzbrite. From the pics it looks like it is the same as the popular TZ82 schematic with (4) 470K resistors but with one additional resistor to ground from the collector of Q2. That would make it different from posted schematics as he claims but it looks like there are at least 4 versions of the circuit now: germanium, silicon w/ 4 resistors. silicon w/ 5 resistors, and encapsulated.
Thread here: http://www.thegearpage.net/board/showth ... 787&page=4 The pic is B&W so you can't read the color codes and I think there is another capacitor hiding behind the large one.
- analogguru
maybeThat would make it different from posted schematics.....
wrong........ as he claims but it looks like there are at least 4 versions
.... because the "silicon w/ 4 resistors" always contained 5 resistors. The fifth resistor is a 22k to ground placed directly at the potentiometers.... of the circuit now: germanium, silicon w/ 4 resistors. silicon w/ 5 resistors, and encapsulated.
Not verified yet is if the encapsuled version is identical to the silicon version.
- theehman
If you look at the silicon schematic circulating on the 'net it doesn't have the 22K to ground Analogguru mentioned. I RE'ed a ZB Custom rebranded Fuzzrite years ago and it did have the resistor in it, which actually goes from the junction of the .002 cap from Q2 and the lug of the Depth control to ground.
What does the 22K do in the circuit? I've seen the same arrangement in other fuzz circuits.
Ron Neely II
fx schematics and repairs
- soulsonic
High pass filtertheehman wrote:What does the 22K do in the circuit? I've seen the same arrangement in other fuzz circuits.
- analogguru
I don´t care much about wrong schematics on thew net - there are too many.theehman wrote:If you look at the silicon schematic circulating on the 'net it doesn't have the 22K to ground Analogguru mentioned.
In the actual units there was this 22k resistor - in both versions - as you can see below.
As soulsonic said it acts (together withe the 2n capacitor) as a high-pass-filter.What does the 22K do in the circuit? I've seen the same arrangement in other fuzz circuits.
- doug deeper
to be fair, the missing 22k resistor does change the sound quite a bit.
- Uma Floresta
Silly putty? Bubble gum?
- theehman
Bondo is what I've read.Uma Floresta wrote:Silly putty? Bubble gum?
Ron Neely II
- soulsonic
Should say, "It is there so I don't have to bother making a board for it."Fuzzer wrote:That says the builder.The chewing gum is bondo. It is there to protect the parts inside.
I have successfully de-gooped a Fuzzbrite belonging to a friend. The pictures show the standard 5 resistor circuit (4 x 470K and 1 x 22k). It's exactly the same as the schematic theehman posted except the transistors are PN2222A (labeled CENPN 2222A) . The pot values are also the same.
My first de-goop!
My first de-goop!
- Uma Floresta
I'm surprised he's not using the the metal can 2N3904 or whatever transistors from the original. If you're going to go mojo with the carbon comp resistors, why not go the whole nine yards?HonkyMofo wrote:I have successfully de-gooped a Fuzzbrite belonging to a friend. The pictures show the standard 5 resistor circuit (4 x 470K and 1 x 22k). It's exactly the same as the schematic theehman posted except the transistors are PN2222A (labeled CENPN 2222A) . The pot values are also the same.
My first de-goop!
- theehman
Nice work on that. So, it looks like it's the same as my Fuzz-O-Matic, except I use different transistors.
Another mystery laid to rest.
Ron Neely II
- theehman
The original transistors were TZ82 made by Sprague. Hard to find these days.Uma Floresta wrote: I'm surprised he's not using the the metal can 2N3904 or whatever transistors from the original. If you're going to go mojo with the carbon comp resistors, why not go the whole nine yards?
Ron Neely II
- Uma Floresta
Ah, thanks for correcting me.theehman wrote:The original transistors were TZ82 made by Sprague. Hard to find these days.Uma Floresta wrote: I'm surprised he's not using the the metal can 2N3904 or whatever transistors from the original. If you're going to go mojo with the carbon comp resistors, why not go the whole nine yards?
- chicago_mike
PLAYDOH!
Skyline FX 2013
