Catalinbread - SFT  [traced]
Re: Catalinbread - SFT
Postby deltafred » 19 Jun 2011, 21:58
mothercruncher wrote:Hmm, just got back from hols and had a good session with this tonight- did anyone have an issue with HUGE volume with the vero layout for this?
The volume pot is basically barely doing anything and, stock, it's (probably rightly) running so much louder than when in bypass :hmmm:
It sounds like you could have no ground connection to the volume pot, either a faulty pot or bad soldered joint ( but looking at you photos I would very much doubt a bad joint).
Really neat build, love it. I would also like to thank Mike for his vero layout and all the guys involved in tracing it.
I have built 3 so far and none have had volume issues, one was very unstable and gated but that turned out to be me missing a track cut. :roll:
deltafred
Has thanked: 364 times
Have thanks: 254 times
Postby ShortScaleMike » 20 Jun 2011, 09:10
mothercruncher wrote:Many thanks to Mike for the ver0 layout and rcubed and the original tracers who put the hard yards in. :applause:
No worries, beautiful build.
ShortScaleMike
Has thanked: 19 times
Have thanks: 92 times
Postby mothercruncher » 20 Jun 2011, 16:03
Argh, how embarrassing- I should have spotted that one- nothing was getting bled through to ground. That pot was the one component I recycled for the project too, that'll teach me.
Thanks for the spot DF :applause:
mothercruncher
Postby deltafred » 21 Jun 2011, 15:49
mothercruncher, glad to be of help.
If I have a problem with something electronic I usually phone a good friend of mine and talk through it. Usually it hits me as I am having to think it through to explain it to him (he is also a retired EE). When you have built something you usually imagine the worst.
deltafred
Postby neoflox » 31 Dec 2011, 18:39
did anyone ever compared an original SFT with a cloned one? I did back when the first verified layouts came out and I remember it sounding significantly different. Less overall gain, shitty sound with lowered gain. If someone is certain to know a equally sounding layout, please tell which one it is ;)
neoflox
Have thanks: 2 times
Postby DWBH » 12 May 2014, 21:37
Here's one I built for my bassist friend of mine.
Regarding the weird connection on the pot, you're all talking about that connection between lug2 and the resistor to ground right? What's the catch? Should it be eliminated?
Haven't tried it with bass, only with guitar, and although I thought it would be more gainy, it's very amp-like, almost tweed-ish.
DWBH
Have thanks: 4 times
Postby deltafred » 12 May 2014, 22:57
DWBH wrote:Here's one I built for my bassist friend of mine.
It's a while ago so I had to go look at the schematic to see what what was going on around the gain pot and realise that I have wired mine incorrectly and that was probably causing the high gain with the gain pot right down. I should think that if you wire it as the schematic (and not incorrectly as I did) then it should be fine.
I have used mine on both guitar and bass, I built it for bass but sounds nice with guitar.
It is supposed to sound like an Ampeg SVT bass amp, with a similar sound when you overdrive it. Having only ever played bass through an Ampeg rig once I cannot say how true this is. We were the support band and the Ampeg rig belonged to the headline band so I didn't want to mess with it. I just plugged in and it sounded ok as he had it set so played it like that.
deltafred
Postby Sonofthebeach » 04 May 2015, 10:15
I built this one yesterday and am not sure that it works right cause the pedal behaves not "normal" compared to other overdrives.
Only with gain maxed the pedal has a good sound. low gain settings let the overall volume drop. With low gain settings the volume has to be cranked but when I crank the gain the volume gets way too loud. But with the volume on half or below there is less gain...
I used a madbean faultline pcb. I already put a linear volume gain pot in....
When comparing to youtube demos I notice that the original units do not seem to have those problems.
Has anyone an idea whats going on?
Sonofthebeach
Postby greenskull » 11 May 2015, 01:53
Sorry to say I built the Faultline years ago and was disappointed I couldn't really match the demo of the real thing. Seemed like not enough gain from what I remember.
greenskull
Has thanked: 37 times
Have thanks: 9 times
Postby tapion » 15 Jul 2016, 10:17
Hey there,
i'm still having problems getting my build (tagboardeffects vero) to work (using J111s as Q1-Q6 until the replacements arrive...)
Does anyone have important bias points i could measure in the meantime?
Well at least the case is finished ;)
For this message the author tapion has received thanks:
ozzy666 (15 Jul 2016, 23:39)
tapion
Postby tapion » 22 Jul 2016, 07:48
Small update: in the meantime my build works with 2n5457s, but has incredible amounts of gain and oscillations in one switch setting, maybe the PN4393s will fix this...
ozzy666 (23 Jul 2016, 10:12)
tapion
Postby Stymie13 » 09 Nov 2016, 16:05
I know this is an old one but I'm not able to get this one working properly. All component values, locations, tracks, cuts, links, wiring, etc. has been double, triple, and quadruple checked. The tone controls work as do gain and volume but the sound is terrible. Anyone who has a properly working SFT II version, please post your FET drain voltage readings. With J201, 5457, 5485, and MPF4393s the voltages were very similar:
Q1 .58-1.08
Q2 9.4
Q3 2.5-3.5
Q4 9.4
Q5 5.16-5.45
Q6 9.4
Stymie13
Postby Stymie13 » 11 Nov 2016, 06:14
Found an incorrect resistor biasing Q1 and swapped it out. Working properly after correcting a switch wiring issue also.
Q1 4.8
Q2 9.4
Q3 4.1
Q4 9.4
Q5 5.2
Q6 9.4
Stymie13
Postby rankotomic70 » 02 Dec 2016, 19:35
I built ver. I using Ampegulator PCB (schematics is the same), but I have some high frequency hiss (about 8kHz) when running charge pump switched to 18V. Does anyone else has the same problem with 18V charge pump? Any hints?
rankotomic70
Postby rankotomic70 » 03 Dec 2016, 09:33
Now I have checked - hiss is at 10kHz, and it is due to the fact that I have used TLC7660A instead of TLC7660S (which I couldn't buy here). S version of that IC has frequency boost at pin 1, while A doesn't have that, and it's internal working frequency is 10kHz. I will try to filter it out using a 10n capacitor between +18V and ground, but for all of you who want to build this (or any other pedal) using charge pump - DO NOT use TLC7660A, use TLC7660S only!
For this message the author rankotomic70 has received thanks:
ozzy666 (03 Dec 2016, 23:38)
rankotomic70
Postby Jiomy » 13 Feb 2017, 02:08
Hello , i recently finished my SFT Build and the stoner mode is way too loud for switching it live , so i would like to ask if anyone here can point me to the right direction to make it usable for live situations to work the stoner mode as a little gain boost. My first thought was maybe lowering the value of the electro that the switch enables. You see i am not a so much of a fun of how the stoner mode sounds on my keyboards (organ), so maybe i have to add/remove something else from another place in the circuit to get what i want. Any pros here that can give me a tip about that?
:thumbsup
Jiomy
Postby etta place » 13 Feb 2017, 19:49
maybe put a 2 to 10K trimmer in series with the electro,and adjust it to taste.
or,use a standard pot,adjust,measure and replace it with a fixed resistor
η πεσ στο στελιο να σου δωσει το τηλεφωνο μου :lol:
For this message the author etta place has received thanks:
Jiomy (15 Feb 2017, 12:29)
etta place
Postby n4m3less » 08 Apr 2017, 08:24
Blend wrote:If I connect the capacitor 22uF, the problem arises, but with the complete switch as in the original I do not hear any crackling noise, other mod that suggest you do in the 1st SFT is to replace R5 22k with 10k. :wink:
Hi! i have made the mods recommended by Blend...one question: the 47pf add on q8, what does?what kind of changes in the sound?
thanks
P.S: to my ears the first version with these mods sounds better than the last version.Someone Confirmation?
n4m3less
Postby elbeeuk » 21 Jul 2017, 23:02
Hi all,
I'm hoping someone can help point me in the right direction with debugging this build.
I've built it all and the circuit lets the signal through when engaged but the gain is weaker than demos. The layout I used is over at http://tagboardeffects.blogspot.co.uk/2016/06/catalinbread-sft-ii.html
The main problem I'm having though is that I get a weird squeal when stoner is engaged. Here's a quick vid to explain better in terms of pots involved:
https://photos.app.goo.gl/1Bwv7Qc03aNyy5g03
Can anyone think where to start with debugging? I've built 4 other pedals without issues, this is the first that's giving me bother.
DPDT switch is wired lkike this:
https://photos.app.goo.gl/d839CmHh40PKJbrE2
Solder on the veroboard looks like this:
https://photos.app.goo.gl/Vqg7srdPfQ6kB6a03
https://photos.app.goo.gl/YRxqSaZpcJJ4YAnO2
https://photos.app.goo.gl/O91edceJB54DqYpu1
Give me a shout if you need other info that might help.
Elbee
elbeeuk
Previous
Users browsing this forum: kenny Treble, Pokfor and 25 guests
