Catalinbread - Formula No. 5 [traced]
- bigmufffuzzwizz
Yea I'm not sure about those 2N584. Never heard of those before and I did a quick search without any real results. The closest I found was 2N5840 but I feel like that might be a whole nother transistor altogether. Anyways whatever you have here is what the build doc ask for. And cheap!!!
http://www.futurlec.com/cgi-bin/search/search.cgi and type in "2N5457"
Yes I was referring to the bottom of the vero. If you grab some flush cutters you can trim the leads all the way down to where the top of the solder volcano/hersey kiss forms. It could also be that I was too careful!
Here's some cheap cutters for an example:
http://www.google.com/products/catalog? ... CDwQ8gIwAw#
Magic Pedals Home of The Shrine Fuzz!
Yeah, it was a typo but I used all 2n5457's.coldcraft wrote:i'm going to guess that 2n584 was a typo and they meant 2n5458
- coldcraft
when I get some time, I'm going to make a new board layout for board-mount pots and possible a switch to go connect/disconnect the 2M2 that some people have done.
- mich
oops ... and the part list:
cat5.brd
Part Value Package Library Position (mil) Orientation
+9V1 +9V(T) SQUARE gm-supply (1350 1800) R180
C1 2u2 050_020_2 gm-caps-electro-pol (300 2050) R270
C2 1n 075X030 gm-caps-film-chicklet (850 2100) R180
C3 4u7 050_020_2 gm-caps-electro-pol (1350 2600) R0
C4 47u 050_020_2 gm-caps-electro-pol (1950 2000) R0
C5 100n 050_020_2 gm-caps-electro-pol (1050 2550) R90
C6 1n 075X030 gm-caps-film-chicklet (1100 2200) R270
C7 470p 075X030 gm-caps-film-chicklet (2150 2500) R0
C8 4n7 075X030 gm-caps-film-chicklet (2400 2500) R270
C9 100n 075X030 gm-caps-film-chicklet (2050 2650) R0
C10 100n 075X030 gm-caps-film-chicklet (1600 1750) R180
C11 47n 075X030 gm-caps-film-chicklet (1600 2250) R180
C12 1n 075X030 gm-caps-film-chicklet (600 2700) R180
D1 1N4001 DO41-3 gm-diodes (2200 1800) R90
GAIN 1MA 16MM-PCB-MOUNT gm-pots (1350 2800) R180
GND1 GND(T) SQUARE gm-supply (250 2800) R180
IN SQUARE gm-supply (250 2250) R180
Q1 2N5457 TO92- gm-trans (1300 2400) R0
Q2 2N5457 TO92- gm-trans (850 2300) R180
Q3 2N5457 TO92- gm-trans (1900 2200) R0
Q4 2N5457 TO92- gm-trans (1650 1950) R180
R1 10k R0207/3 gm-resistors (1700 2700) R90
R2 47k R0207/3 gm-resistors (2150 2200) R270
R3 1M R0207/3 gm-resistors (250 2500) R270
R4 62k R0207/3 gm-resistors (450 2200) R90
R5 1M R0207/3 gm-resistors (650 2200) R90
R6 1M R0207/3 gm-resistors (1700 2400) R180
R7 1M R0207/3 gm-resistors (1600 2100) R0
R8 10k R0207/3 gm-resistors (750 2550) R180
R9 1M R0207/3 gm-resistors (2300 2200) R270
R10 1M R0207/3 gm-resistors (1950 1800) R180
R11 1M R0207/3 gm-resistors (1950 1700) R0
R12 10k R0207/3 gm-resistors (1150 1950) R0
R13 47k R0207/3 gm-resistors (550 2300) R90
SW1 SPST SPST gm-switches (850 2450) R180
TONE 1MB 16MM-PCB-MOUNT gm-pots (2100 2800) R180
VOLUME 500kA 16MM-PCB-MOUNT gm-pots (600 2800) R180
cat5.brd
- joeboo88
Hi Reverend, here is a link on off board wiring. If i understand your question, usually the output from the fooswitch would go
to the output jack.
but you can look up what you need here
http://www.generalguitargadgets.com/tec ... ng-options
good luck
to the output jack.
good luck
Ebay is a fucker ~ Sinner - If this is something unique, then I'm a teletubbie ~also Sinner
- Barcode
FYI to anyone building this, bear in mind that the poster has inexplicably flipped the PnP, so the component layout shown is backwards. I'm building from this layout right now, if it is verified I will post a pdf file with the PnP in the correct orientation.mich wrote:Here ya go: (all 300 dpi)
- Barcode
Haven't verified it yet, it is populated but I haven't wired it up yet. But here is the corrected project file anyway, with the proper PnP orientation.
- Catalinbread_Formula_No_ 5.pdf
- Catalinbread Formula 5 Project File
- (105.18 KiB) Downloaded 696 times
- Barcode
I used a 2n5457, a 2n5458, and 2 j201's. Mine does NOT sound right, and I'm guessing it may have to do with the fact that J201's are pretty notoriously inconsistent. Thoughts?joeboo88 wrote:I forgot to mention i used 2 2n5484's and 2 j201's and my build sounds like its supposed to, but maybe he should use 4 2n5457's like you suggest.
- Barcode
I can definitely say it's verified (I did manage to poulate the board backwards so that it would work ) I'm just not getting very good sound from it. I'd put money on it being the fets for me.mich wrote:Oh and it's verified. I built a few
By the way, no ill will intended, I thoroughly appreciate you posting the layout!
Why the flip though? If you printed as you have posted it onto transfer paper, it will etch backwards.
- Ice-9
- Degoop Doctor
mich wrote:No worries ... I use this format as a mask for my uv transfers. Guess I could just flip the transparency huh lol
It's best not to flip the transparecy when using light to develop a pcb as the you want the toner on the side of the transparency that contacts the pcb, this way you get less light leakage and crisper traces.
Hi there !
Is this Layout veryfied? ! Barcode, have you been able to work it? Anybody?
