A/DA - Final Phase  [schematic]
A/DA - Final Phase
Postby borislavgajic » 16 Mar 2010, 11:35
http://www.adadepot.com/adagear/gearpag ... -Phase.htm
and trasce side from e-bay......
Boris
borislavgajic
Has thanked: 140 times
Have thanks: 252 times
Re: ADA Final Phase
Postby Bernardduur » 16 Mar 2010, 16:34
Schematic can be found on the page Boris added!
Bernardduur
Has thanked: 87 times
Have thanks: 490 times
Re: ADA Final Phase
Postby borislavgajic » 16 Mar 2010, 18:49
Bernardduur wrote:Schematic can be found on the page Boris added!
:thumbsup that is the reason why I did that :)
Boris.....
does enybody have the real thing?...those sound clips are not so special...? or I am mistaking?
borislavgajic
Re: ADA Final Phase
Postby Scruffie » 16 Mar 2010, 19:00
Those soundclips aren't the best are they but I always hear good things about this box...
I'm hoping now there's the reissue's out some people will post some new youtube demos of it because I still haven't quite found a phaser I really like so I have high hopes for this one.
Scruffie
Has thanked: 28 times
Have thanks: 144 times
Re: ADA Final Phase
Postby SPeter » 16 Mar 2010, 19:15
Thanks Bore!
:applause:
:thumbsup
:D
SPeter
Have thanks: 76 times
Re: ADA Final Phase
Postby Ed22 » 28 May 2010, 11:23
Scruffie wrote:Those soundclips aren't the best are they but I always hear good things about this box...
Link
it doesn't sound as "standard" phasers do...
Ed.
Ed22
Re: ADA Final Phase
Postby Scruffie » 28 May 2010, 18:09
http://www.youtube.com/watch?v=-j9Uf_uiSc8
Ed.
Hmm that's actually kinda nice, certainly reminds me of 70s phasing off some kind of TV Theme tune or something (although that could be the riff being played) not too sure about the overdrive though and a tad too complex to probably be worth cloning.
Scruffie
Re: ADA - Final Phase
Postby modman » 08 Feb 2015, 16:06
I cannot believe this? No schematic?
Has thanked: 3283 times
Have thanks: 611 times
Postby armdnrdy1 » 08 Feb 2015, 21:37
I cannot believe this....only one schematic? :lol:
armdnrdy1
Have thanks: 68 times
Postby armdnrdy1 » 08 Feb 2015, 21:45
For this message the author armdnrdy1 has received thanks: 2
locker (08 Feb 2015, 22:05), snk (25 Apr 2019, 15:46)
armdnrdy1
Postby Scruffie » 09 Feb 2015, 18:23
You mention in the gut shots thread that there are some issues in the schematic, care to elaborate?
I breadboarded that weird OD pot set up a while ago, seems to work okay with just a standard pot and not a tapped one.
Scruffie
Postby armdnrdy1 » 10 Feb 2015, 16:44
Hey Scruffie,
The Sweep Modulation pot (P3) is drawn incorrectly on the factory schematic 1087. (version 7)
When the control is turned clockwise, there should be more resistance between the inverting input and the output of the modulation oscillator op amp. (IC5B)
Version 5 (vactrol version) is drawn incorrectly as well. The factory schematic 1069 (version 9) is drawn correctly. It usually wouldn't matter, you could switch the wires on the lugs but...my build includes board mounted pots as in the original.
After I sourced some dual 50K center tapped pots for another project, I too bread boarded the drive circuit. I found that both ways worked as a drive control but, the center tapped version attenuated the drive output a bit.
Since then I found a trace side image which shows the drive area. I was able to verify that it is not a center tapped pot.
I still can't understand why it was drawn in that fashion!
Now for some good news! Yesterday was my Birthday. (that's not the good news) I decided to purchase a Birthday present for myself.
I bought a Final Phase, (reissue) and a NOS A/DA Control Pedal A.
After these items arrive, I'll dig in and reverse the reissue. I'll also be able to take readings for the clock adjustments.
The build I'm working on includes true bypass, a power supply input that accepts 18VDC or 12VAC, (as I did with the Mutron Flanger) a drive switch indicator LED, and a NPN buffered rate indicator LED for the IN/OUT effect switch.
The build is a bit smaller than the original, (fits in a 1590X enclosure) includes long pin, right angle board mounted pots, and board mounted low profile footswitches. (smaller footprint)
Here is a "sneak peek" of the board.
For this message the author armdnrdy1 has received thanks: 5
Blitz Krieg (17 Feb 2015, 08:25), GodSaveMetal (16 Mar 2015, 04:52), modman (11 Feb 2015, 14:54), Scruffie (16 Feb 2015, 21:34), selfdestroyer (18 Feb 2015, 06:31)
armdnrdy1
Postby armdnrdy1 » 17 Feb 2015, 04:02
I received the reissue Thursday...and have been hard at work tracing the circuit.
It's a double sided board, smaller than the original, mostly 1/8W resistors.
The promo releases, and the user manual say that the drive section has been changed to a more "modern" sound. All that I see is an increase in gain and a cap added in the drive feedback loop. I guess louder/more distorted is "modern." :hmmm:
I post the schematic when finished.
modman (22 May 2015, 22:21)
armdnrdy1
Re: ADA - Final Phase  [schematic]
Postby armdnrdy1 » 20 Feb 2015, 04:38
Here's the Final Phase reissue schematic.
For this message the author armdnrdy1 has received thanks: 4
GodSaveMetal (16 Mar 2015, 04:52), Intripped (20 Feb 2015, 05:15), modman (22 May 2015, 22:19), tp801 (20 Feb 2015, 08:25)
armdnrdy1
Postby armdnrdy1 » 20 Feb 2015, 04:43
Reissue schematic PDF:
For this message the author armdnrdy1 has received thanks: 6
Dirk_Hendrik (20 Feb 2015, 21:27), Fender3D (20 Feb 2015, 20:17), GodSaveMetal (16 Mar 2015, 04:52), modman (22 May 2015, 22:19), Scruffie (20 Feb 2015, 11:26), uncleboko (20 Feb 2015, 08:46)
armdnrdy1
Postby uncleboko » 20 Feb 2015, 14:58
It's 4047/4007 time again, can't beat it for pils widdle moddle
uncleboko
Has thanked: 55 times
Have thanks: 22 times
Postby armdnrdy1 » 20 Feb 2015, 16:33
uncleboko wrote:It's 4047/4007 time again, can't beat it for pils widdle moddle
Yes...one of my favorite clocks as well.
A couple things of note:
The component designations on my drawing do not match the actual circuit board designations.
The resistor designations are printed under the resistors. It would have been necessary to pull all of the resistors to record the exact numbering.
All of the .47µf caps are monolithic ceramic. (MLCC) These caps were designated in the original factory documents.
The reissue circuit compared to the original.
My thoughts are...the reissue seems to have changes that appear to be nothing more than to lower the component count/cost.
I feel that the original had better local IC power filtering.
The reissue shares the voltage reference between the LFO and the signal path op amps. The original had separate VR.
The reissue is a double sided board with mostly 1/8W resistors. The reissue pc board is about 15% smaller but..is housed in the same sized enclosure as the original so...what is the advantage?
The original used quite a few tantalum capacitors for power filtering. The reissue uses less costly aluminum electrolytic caps.
I may add the reissue drive section to my build but..I'm pretty sure that I would have to include the reissue's changes in the feedback circuit, (Intensity) and the output section to compensate for the added drive gain.
modman (22 May 2015, 22:19), uncleboko (18 Jan 2017, 19:44)
armdnrdy1
Re: A/DA - Final Phase
Postby Pokfor » 18 Jan 2017, 09:40
Hello!
My job.
Scheme
PCB File
Final Phase.zip
The device is designed to use the body Gainta B023
I could not find this on the VCO tuning frequency is determined therefore on the rumor turned out range from 40kHz to 1 MHz. If someone known to the factory settings will be very grateful.
Made more modification changes the waveform with the LCO with the triangle on the sine wave.
For this message the author Pokfor has received thanks:
borislavgajic (16 Feb 2017, 21:53)
Pokfor
Has thanked: 10 times
Have thanks: 13 times
Postby Dirk_Hendrik » 19 Jan 2017, 20:03
Great job!!
Has thanked: 255 times
Have thanks: 1035 times
Postby armdnrdy1 » 25 Jan 2017, 03:32
I'm not sure which version you based your build off of....but this is the reissue frequency reading.
I took frequency readings at the test point (pin 10) of the 4047.
With all controls CCW and the Range control CW, I measured:
min. 34kHz
max. 537kHz
The reissue CV is 15 volts. The original is 5 volts.
There are changes in the CV section (IC5D) and the LFO section of the reissue, but I would imagine that the clock frequency would be the same for both versions.
armdnrdy1
Next
Users browsing this forum: Google [Bot], tuti38 and 2 guests
