Colorsound - Power Boost / Overdriver
Postby freedreamer » 09 Dec 2007, 21:29
hi ,
anyone has schematic and/PCB of this pedal?
thanks for the help
freedreamer
Postby analogguru » 09 Dec 2007, 22:06
As far as I know it should be (nearly?) identical to the Colorsound Overdriver
Have thanks: 116 times
Postby modman » 27 Dec 2007, 19:11
http://homepage.ntlworld.com/s.castledi ... erdrv.html
This page contains schematic, pcb files and parts layout for the overdriver and confirms: "The Overdriver was introduced in the early '70s. I believe it was originally sold under the name "Power Boost".
[/img]
Has thanked: 3267 times
Have thanks: 608 times
Postby snail » 27 Dec 2007, 21:24
I love this pedal!
Is the tonestack to be taken as baxandall?
snail
snail
Postby Goop_buster » 29 Dec 2007, 01:13
This booster is a highly recomended build.
Check out Arons forum for additional info about some minor errors or if it was wrong component values in the schematic (if I remember right).
Back in the days people like Jeff Beck and Jan Akkerman used this booster
Akkerman - > http://www.youtube.com/watch?v=bpV5InLw52U
Do not let the sloppy beginning fool you. This guy play some amazing stuff and absolutely tears up the guitar neck ...for being 1973 :wink: .
Goop_buster
Have thanks: 5 times
Postby foxfire » 29 Dec 2007, 04:41
if the power booster is the same circuit as the overdriver then i'd have to agree. i love my overdriver. it's just a ballsy pedal.
foxfire
Postby analogguru » 06 Jan 2008, 02:46
really awful how they mixed up the capacitors in the tone-control section. If there woudn´t be the picture I wouldn´t believe it.
Bernardduur: My '96 Colorsound Overdriver wrote:So
This was the first pedal I ever bought; I was on a vacation in England and ventured into Sola Sound shop, somewhere in London. I had to choose between the Tonebender and this box; you know which one I chose. It has been on my board now for years and years...... Awesome pedal!
Old schematic which can be found on the internet
Same schematic but now with altered values for my '96 unit
Transistors are BC184L's. The only thing missing from the schematic is the 1M to ground pull down resistor and the 100k volume potmeter
Postby bajaman » 06 Jan 2008, 02:53
Notice those nice quality HIGH VOLTAGE capacitors for nice tone :wink:
Has thanked: 458 times
Have thanks: 1584 times
Postby JHS » 06 Jan 2008, 11:48
I have 3 different schems of the old OD (early years) and maybe C-sound made even more variations on the original circuit. C-sound used different trannies in the '70-ties and always modified parts in the circuit to adapt different trannies. IMHO they have done the same thing on the '96-model or at least some improvements. Soundwise there will be no or only a slight variation in tone compared to the old units.
2x100n caps + a 10k pot on the treble control is OK, old units have 2x10n caps + a 100k pot. The frequency curve for both combinations is equal.
Often due to dried out or weak electrolytic caps most old C-sound ODs sound muddy and after a re-cap those ODs sound like the should. Replacing those coupling caps with metal film caps like on the '96 is a very good upgrade and 470n is OK. Electrolytic coupling caps are often chosen 10 times bigger than there metal film counterparts to compensate the heavy bass-frequency losses electrolytics are known for.
JHS
JHS
Have thanks: 3 times
Postby Bernardduur » 06 Jan 2008, 12:25
She sounds pretty good, although the gain control doesn't do much until it is at 75% or so....... then the unit becomes gritty and fuzzy
I use it mainly with the gain at 0 boosting the amp; it has a lot of volume!
Bernardduur
Has thanked: 87 times
Have thanks: 489 times
Postby Bernardduur » 06 Jan 2008, 16:53
Underside to complete the picture; notice the marking "Powerboost 96" :)
Bernardduur
Postby analogguru » 06 Jan 2008, 16:58
Hey cool, thanks !
Postby lautmaschine » 08 Jan 2008, 04:29
The Akkerman sloppiness at the beginning is totally intentional. The 'broken' beginning eventually became the trademark of Hocus Pocus live.
Akkerman is quite the eccentric guy. Back in the day he loved Les Pauls but couldn't stand how little treble they produced. He was always on about how important it was to get the most treble possible in his sound.... I remember reading interview after interview of the guy spelling out his recipes for guitar sound as if it was gospel.
But yeah, a monster on the neck for sure. What a great song that was.
lautmaschine
Postby JimiB » 08 Jan 2008, 18:42
what trannys are those?
JimiB
Postby MoreCowbell » 08 Jan 2008, 18:48
JimiB wrote:what trannys are those?
Bernardduur wrote:Transistors are BC184L's.
:D
MoreCowbell
Have thanks: 11 times
Postby pf_fan » 03 Feb 2008, 23:40
This schematic of '96 Colorsound Power Boost shows two 22uF capacitors. When I looked at PCB shot I noticed three 22uF caps. Is something wrong with the schematic or am I blind? :)
pf_fan
Postby Bernardduur » 04 Feb 2008, 07:57
pf_fan wrote:This schematic of '96 Colorsound Power Boost shows two 22uF capacitors. When I looked at PCB shot I noticed three 22uF caps. Is something wrong with the schematic or am I blind? :)
Your not blind; I think I missed it :). The cap is placed between the V+ and ground
Bernardduur
Postby pf_fan » 04 Feb 2008, 09:03
Bernardduur wrote:Your not blind; I think I missed it :). The cap is placed between the V+ and ground
Thanks. Is it this one?
I think that I noticed one more thing. I counted 15 resistors on PCB. Schematic have only 14. To make things more complicated I found another picture of the PCB which has... 16 resistors! I circled this additional one :)
pf_fan
Postby sonicvi » 04 Feb 2008, 17:41
I have Prescription's version of the Overdriver and it uses 2N3904's rather than BC types. BC184C's I have are much higher gain than 3904's I have. Should there be a great deal of difference in sound between the two types in this circuit?
sonicvi
Have thanks: 12 times
Postby Bernardduur » 04 Feb 2008, 18:54
I'll check it tonight!
Bernardduur
Next
