Earthquaker Devices - Crimson Drive [traced]
- RnFR
well, there goes the "original" thing!
- culturejam
Hey, it's got a buffer!! That's pretty new.RnFR wrote:well, there goes the "original" thing!
At the very least, the build quality looks to be pretty good, and the prices aren't insane.
- mich
So based on the schematics here, I did a board mounted pcb layout. I included a partlst but I have to confess I'm not sure about the fractional-value capacitor listings
Part Value Package Library Position (inch) Orientation
+9V1 +9V(T) SQUARE gm-supply (1.45 0.7) R0
C1 100n 070X030_3 gm-caps-film-chicklet (0.5 2.45) R0
C2 1/50 050_020_2 gm-caps-electro-pol (0.2 0.6) R180
C3 100/16 050_020_2 gm-caps-electro-pol (0.3 1.35) R180
C4 100/16 050_020_2 gm-caps-electro-pol (1.7 0. R0
C5 10/16 050_020_2 gm-caps-electro-pol (0.9 2.45) R0
C6 100N 070X030_3 gm-caps-film-chicklet (1 2.15) R270
C7 100P 070X030_3 gm-caps-film-chicklet (1.65 1.65) R180
C8 100/16 050_020_2 gm-caps-electro-pol (0.7 1.5) R90
C9 1/50 050_020_2 gm-caps-electro-pol (1.25 2.25) R0
D1 LED5MM LED5MM gm-diodes (1 1.1) R90
D2 1N4148-3 DO35-3 gm-diodes (1.65 1) R0
D4 1N60P DO35-3 gm-diodes (1.45 2.05) R0
D5 1N60P DO35-3 gm-diodes (1.65 1.15) R0
D6 1N4001 DO35-3 gm-diodes (1.6 2.3) R270
GAIN 100kB POT gm-pots (0.5 2.65) R0
GND2 GND(T) SQUARE gm-supply (0.2 0.1) R0
IN SQUARE gm-supply (0.35 0.35) R0
LEVEL 100KA POT gm-pots (1.5 2.65) R0
OUT SQUARE gm-supply (1.5 0.4) R0
Q1 J201 TO92- gm-trans (0.8 2.1) R90
Q2 AC128 TO5 gm-trans (0.95 1.75) R270
R1 10K R0207/4 gm-resistors (1.2 0.85) R180
R2 2m2 R0207/4 gm-resistors (0.55 0.4) R90
R3 4k7 R0207/4 gm-resistors (1.3 2.45) R0
R4 1M R0207/4 gm-resistors (0.35 1. R90
R5 1M R0207/4 gm-resistors (0.4 2.15) R180
R6 4K7 R0207/4 gm-resistors (0.5 2.3) R180
R7 68K R0207/4 gm-resistors (1.3 1.45) R90
R8 470K R0207/4 gm-resistors (1.6 1.3) R0
R9 2K2 R0207/4 gm-resistors (0.55 1. R270
R10 15K R0207/4 gm-resistors (1.6 1.85) R0
STOMP 3PDTBLUE CHINABLUE gm-switches (1 0.4) R0
Parts list:Part Value Package Library Position (inch) Orientation
- 300 dpi
- PNP_transfer_RP.png (10.97 KiB) Viewed 5011 times
- RnFR
the "fractional value" is just value/voltage. thanks for the layout!
yeah, I like their stuff. I'm definitely a fan of the sounds that he focuses around, and the general aesthetic is very cool, too.culturejam wrote:Hey, it's got a buffer!! That's pretty new.RnFR wrote:well, there goes the "original" thing!
- Hides-His-Eyes
Make sure those pads are big enough for 2mm drills.
- RnFR
that's a good point. I've recently started doing some more iron on transfer etching, and I'm really not having fun. I've decided to start making the pads huge, even though I generally use #68 drill bits, and at least .05 traces for easier etching.
- culturejam
I've moved the etching methods discussion here:
https://www.freestompboxes.org/viewtopic ... 22&t=12971
Please can tell me somewone, what a hFE ist the best value for the AC128
Actually i can't, but here's a vero layout i did a while ago for practising purposes.
I would be glad if someone could check this, its not verified yet.
- eqd_crimsondrive.gif (27.06 KiB) Viewed 4720 times
- IvIark
Dirk, is the orientation of C3 and C7 correct? C3 with positive to input and negative to supply for C7?
- Manfred
- Has thanked: 1671 times
- Been thanked: 1344 times
The AC128 transitor has a widely spread in DC-current gain,
if only because it is essential to know the gain of the used one to ensure the funktion of the device.
I would appreciate very much, if someone could measure the voltages on the transistor leads and Vcc as well at the original device.
- Manfred
The Q2 stage is derived from the Dallas Rangemaster circuit, from there the gain range of the applied AC128 should be 80 - 100 for best sounding.Manfred wrote:The AC128 transitor has a widely spread in DC-current gain,
- Manfred
I took a snapshot of the Crimson PCB on a demo video.
Which PCB-type is built-in at the latest Crimson version.
There are a glass Germanium transistor and two original 1N60 are applied.Which PCB-type is built-in at the latest Crimson version.
- Manfred
The version with the OC139 NPN Germanium Transistor is definitely the last one.
Can anyone take a better photo of the PCB and excerpt the part values?
I would appreciate it very much.
- Manfred
I have seen that the device is not longer in the product range, I suppose the OC139 transistors are now very rare.
Here the the traced schematic of the OC139 version:
