Catalinbread Manx Loaghtan [guts]
Re: Catalinbread Manx Loaghtan [guts]
Postby mmolteratx » 04 May 2011, 21:25
batteryacidtea wrote:Thank you! I'll post the files ASAP then!
No problem. Thanks for redoing them in Eagle. I really should download it...
mmolteratx
Has thanked: 103 times
Have thanks: 626 times
Postby batteryacidtea » 04 May 2011, 21:30
There you go http://www.4shared.com/file/kButZwdK/Manx_Loaghtan.html
I didn't put any values at the schematics yet, since there's some unknown values, but feel free to modify it!
:horsey:
For this message the author batteryacidtea has received thanks: 2
mmolteratx (04 May 2011, 22:21), Nocentelli (04 May 2011, 21:39)
batteryacidtea
Has thanked: 57 times
Have thanks: 15 times
Postby Nocentelli » 04 May 2011, 21:34
OK, I'm doing a vero layout atm, and I'm puzzled by a couple of things: Firstly, there appears to be no pull-down resistor on the input - How come it doesn't pop? Is this because the 47K resistor is before, not after the input cap? Secondly, the sustain pot has no resistor to ground off lug 1 as per normal muff. I assume the 10n cap across lugs 2+3 is there to preserve treble at minimum sustain, but does it also serve to ensure the signal is not cut off entirely when the wiper is shorted to ground?
Nocentelli
Has thanked: 862 times
Have thanks: 837 times
Postby batteryacidtea » 04 May 2011, 21:36
I don't use any pulldown resistor in my big muff builds, and never had any kind of pop in there!
batteryacidtea
Postby Nocentelli » 04 May 2011, 21:41
OK, cool. I've always just stuck one in as a matter of course in all my builds.
Nocentelli
Postby batteryacidtea » 04 May 2011, 21:53
I'm a little lazy about this, and try all my pedals without it. If it pops, what da hell, i just pup it there, cursing for the extra job. I think I just had pop issues with fuzz faces, rebotes and CE-2.
batteryacidtea
Postby mmolteratx » 04 May 2011, 22:20
Nocentelli wrote:OK, I'm doing a vero layout atm, and I'm puzzled by a couple of things: Firstly, there appears to be no pull-down resistor on the input - How come it doesn't pop? Is this because the 47K resistor is before, not after the input cap? Secondly, the sustain pot has no resistor to ground off lug 1 as per normal muff. I assume the 10n cap across lugs 2+3 is there to preserve treble at minimum sustain, but does it also serve to ensure the signal is not cut off entirely when the wiper is shorted to ground?
I haven't needed one with any Muffs I've built. The input is grounded when bypassed anyways. And yes, the cap keeps the signal from being cut off completely when the wiper is shorted. I did find it odd that there wasn't a resistor to ground but lug 1 of the sustain pot goes directly to ground.
mmolteratx
Postby Greg » 05 May 2011, 01:24
Nocentelli wrote: Secondly, the sustain pot has no resistor to ground off lug 1 as per normal muff. I assume the 10n cap across lugs 2+3 is there to preserve treble at minimum sustain, but does it also serve to ensure the signal is not cut off entirely when the wiper is shorted to ground?
Yes, the cap is there for Treble bypass as the pot is turned down and I can't see how it can maintain a signal.
When the pot is turned all the way down it's grounded (as is the input to the rest of the circuit), and the fact it goes through a cap first is irrelevant.
Greg
Has thanked: 77 times
Have thanks: 195 times
Postby Nocentelli » 06 May 2011, 00:09
Greg_G wrote:When the pot is turned all the way down it's grounded (as is the input to the rest of the circuit), and the fact it goes through a cap first is irrelevant.
mmolteratx wrote:And yes, the cap keeps the signal from being cut off completely when the wiper is shorted. I did find it odd that there wasn't a resistor to ground but lug 1 of the sustain pot goes directly to ground.
:hmmm:
Here's a quick vero (as-per-schematic as far as I can tell):
For this message the author Nocentelli has received thanks: 2
joeboo88 (06 May 2011, 00:23), mmolteratx (06 May 2011, 01:47)
Nocentelli
Postby mmolteratx » 06 May 2011, 01:47
:lol:
That was my understanding. Though I've only had a year of electronics and a couple of years of physics. I start EE courses heavily next year. I'd defer to Greg.
mmolteratx
Postby Greg » 06 May 2011, 02:11
mmolteratx wrote::lol:
I'm always happy to be corrected.. but as I see it, with P1 turned down the junction of C5 and C20 is grounded.
If you take the pot out of the picture, you have 2 capacitors in series with a ground connection in the middle.
Greg
Postby mmolteratx » 06 May 2011, 02:18
Yea, you're right. I missed a 100R resistor to ground from lug 1 of the sustain pot and assumed that was how it was still working. I'll edit the schem and re upload.
mmolteratx
Postby mmolteratx » 06 May 2011, 02:21
Fixed. Sorry guys.
mmolteratx
Postby Greg » 06 May 2011, 02:22
mmolteratx wrote:Yea, you're right. I missed a 100R resistor to ground from lug 1 of the sustain pot and assumed that was how it was still working. I'll edit the schem and re upload.
Thanks mmolteratx
:thumbsup
Greg
Postby mmolteratx » 06 May 2011, 04:21
No problem. FSB has given me a lot since I've joined and I figured it's time to start giving back now that I've got some cool stuff. You can call me Matt BTW.
mmolteratx
Postby Nocentelli » 06 May 2011, 06:09
mmolteratx wrote:FSB has given me a lot since I've joined...
+100
Layout fixed:
Nocentelli
Postby HEAD » 06 May 2011, 06:21
mmolteratx wrote:Fixed. Sorry guys.
One minor fix: In your schematic you used a MOSFET symbol for the 2N5457 JFET - if it is a JFET in the real pedal. Didn't read the whole thread so I don't know.
HEAD
Has thanked: 25 times
Have thanks: 43 times
Postby mmolteratx » 06 May 2011, 06:50
Oops. Noted and fixed in my schem. Dunno how that one happened. :lol:
For this message the author mmolteratx has received thanks:
jonasx26 (08 May 2011, 20:57)
mmolteratx
Postby batteryacidtea » 06 May 2011, 07:13
I'll fix the eagle schematics and try to do a nice layout.
batteryacidtea
Postby burstcracksplit » 07 May 2011, 10:20
I have build it and it sounds (surprise surprise) like a muff with a huge amount of treble. But I think that the value of R21 (100R) is wrong. There's almost no sound if you turn down the sustain pot. On the guts picture R21 looks like 2K (red-black-red-gold). I changed this resistor and now it sounds pretty similar to "low gain" video on youtube.
burstcracksplit
PreviousNext
Users browsing this forum: andy-h-h, Cub, McKenzy and 14 guests
