Frantone - Peach Fuzz  [traced]
bajaman wrote:i built my Peach fuzz without the relay - I have lots of those 3PDT blue footswitches - no clicks or pops either and still true bypass :wink:
can you explain how you did this? i have all the parts on hand except the relay, and i'd like get this built. thanks!
Has thanked: 596 times
Been thanked: 2061 times
simple :wink: - just wire the switch contacts to the relay pads and ignore the relay coil connection pads
great. thanks alot man!
why source out a single pole and a relay when you can do it this way right?
culturejam
Has thanked: 433 times
Been thanked: 563 times
Post by culturejam »
It seems that the last, most recent schematic for the Peach Fuzz has gone missing (the link is no good anymore).
Does anyone have a final schematic for posting? Or can someone email it to me so I can post it?
Cow4prez
Post by Cow4prez »
culturejam
Thanks, Cow!
You're my hero!! :applause:
squrl
Post by squrl »
hmmm does anyone who has this schematic post it up or simply send it to me in a pm? not sure why the images are gone...
members/bajaman/Baja/Baja%20Peach%20Fuzz/PF.png
please read the complete thread for more advanced info :wink:
squrl
Post by squrl »
thank you baja... :block:
picassochild
Been thanked: 8 times
Post by picassochild »
Guys, what do you think about idea to replace original tone control and build Peach Fuzz with Timmy Bass/Treble control? I had Peach Fuzz and liked it, but sometimes low end was too big and woofy.
KindaFuzzy
Has thanked: 79 times
Been thanked: 257 times
Post by KindaFuzzy »
I used Snail's layout and I'm getting a little bit of motorboating with mine. It is in the same case as a SHO, and only happens intermittently when both effects are engaged. I tried moving all the wires and boards around but nothing gets rid of it. I put a 220uf across the power supply, as well as a 47ohm resistor in series with the 9v to each effect and it tamed it down, but didn't kill it.
Anyone else have this problem and figure out how to fix it?
monkeyxx
Has thanked: 52 times
Been thanked: 51 times
Post by monkeyxx »
I just verified a stripboard layout over at this other thread on fsb about the peach fuzz, bajaman's mini peach fuzz thread:
https://www.freestompboxes.org/viewtopic ... zz#p170826
it took me ages to stumble across that thread so I thought i would post a link here, too, as well.
interesting fuzzstortion... kind of sounds like a metal zone or metal muff or something... real crisp and dry sounding, not all phat and juicy and whatnot. Someone made a T Rex (The Slider) comparison and I think that's a good one. I like the "voice" of this circuit, it's got a muffy low end and a certain vocal quality that I always search for and am happy to find in a fuzz distortion or overdrive...it's unique. Don't know if this will be a go-to for me but I'm glad I built it. The Sonic Titan is another really great LM386 distortion device. I also really like the Penny Pedals Fingerprint a whole lot another based on a similar chip.
Has thanked: 4411 times
Been thanked: 2139 times
See BAJA PEACH FUZZ project
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 207 times
Post by grrrunge »
I recently built this one for a friend. Sounds pretty good.
Including the HF-stabilizing components from the data sheet resulted in considerably less hiss while I had the circuit on my breadboard, so I included them in the schematic as well :) Have fun...
mirosol
Has thanked: 192 times
Been thanked: 449 times
Post by mirosol »
Hmm. The unused opamp channel could be used as inverting recovery after the tone stack. It would not need much gain, if any.
http://mirosol.kapsi.fi/
grrrunge
Post by grrrunge »
mirosol wrote:Hmm. The unused opamp channel could be used as inverting recovery after the tone stack. It would not need much gain, if any.
The output signal is being clipped by the LM386 and is rather close to the supply rails.
If the spare op-amp should be used as an output amp without adding more distortion, it should sit after the volume control. Recovery gain shouldn't be necessary here ;)
grrrunge
Post by grrrunge »
I have a stack of spare boards left after building the two i needed.
If anyone's interested, I'll sell them for $4 per board plus postage. PM me for details :thumbsup
marshmellow
Has thanked: 20 times
Been thanked: 127 times
Post by marshmellow »
Concerning the noise, build the first stage as a non-inverting amplifier. The way it's in the original is rather subpar. Make Rf 15kΩ, Rg 910Ω, should give an improvement of over 20dB while keeping the gain the same. The TL022 isn't a particularly great choice either, but maybe it's part of the sound...
V1nce69
my favorite amplifier: Ampeg
Completed builds: Veroboards builds:
Throbak Overdrive Boost
Wampler Ecstasy
Creepy Fingers Doomidrive
Black Arts Quantum Mystic
Roger Mayer Voodoo Bass
Idiot box Blowerbox
Hudson Sidecar
Pcb builds:
Fulltone 69 (GGG kit)
Russian Big Muff (Musikding kit)
EHX Bassballs (home etched using Topopiccione layout)
BJFE BBOD (home etched, thx FSB)
Triangle Muff (Guitar PCB board)
Deluxe Bass Fuzz (home etched,gausmarkov.net layout)
Clone Theory Chorus (Celeste pcb from lectric-fx)
Cornish G2 (home etch, layout thx FSB)
Shin-Ei FY-2 Ge version (home etched, own layout)
Klon (Aion Refractor pcb)
Mutron Phasor II (home etched, layout thx JohnK)
Sunny-T (pcb by guitar pcb)
Rocket Overdrive (pcb by Pepers' pedals)
Sonomatic Deluxe Tape Delay (pcb by Skidmark)
Black Arts Quantum Mystic (adapted storyboardist layout)
Has thanked: 36 times
Been thanked: 110 times
Post by V1nce69 »
bajaman wrote:IMPORTANT UPDATE
The first dual opamp is NOT a TL022, it is definately a TLC (rail to rail opamp) NOT TLO, from the photos posted earlier in this thread. My guess is it is a TLC2262 device.
ALSO
There are 3 different types of LM386N power opamps: The LM386N-1, which is the one used in the Peach fuzz is a 6 volt device. The others are LM386N-3 whch is a 9 volt device and the LM386N-4 which is a 16 volt device.
Cheers
Sorry to resurrect an old thread, but I just wanted to comment that your guess is correct !!
I bought a Peach Fuzz reissue, took a few pictures and traced the board completely.
PeachFuzz_R6A_pcb trace
Peach Fuzz_op amps_closeview
soggybag
Completed builds: Fuzz Face, Tone Bender, Big Muff, ICBM, Ugly Face, Green Ringer, Super Fuzz, Multiplex Echo, Multiplex Jr, Rebote, Echo Base, SHO, Fuzz Factory, Titan Boost/Octave, Easy Face, Tone Bender MkII, Trem Shifter, Zero Point Mini...
Has thanked: 28 times
Been thanked: 27 times
Post by soggybag »
Here’s my build. I designed the PCB and had them manufactured at PCBWay.com it was $5 for 10 boards plus shipping.
This sounds great. Easy to build and the parts are easy to get.
I used the schematic post earlier by grrrunge and included the Zobel networks. I also added a couple pads on pins 1 and 8 of the LM 386’s for the option to boost either of these for fun.
More pictures and details here: http://www.super-freq.com/peach-fuzz-clone/
