Colorsound - Tremolo
MoreCowbell
Been thanked: 15 times
Post by MoreCowbell »
Has thanked: 183 times
Been thanked: 468 times
So, Q4 acts as a switch and shunts the signal to ground, and how much gets divided to ground is determined by the setting of the Depth pot? Clever. I wonder how it sounds compared to the LDR type. I expect it wouldn't have the same hysteresis effect that an LDR has because the on/off time constants would be faster. I wonder how it would sound if you used a FET for Q4? :hmmm:
R.G.
Been thanked: 39 times
Post by R.G. »
Q4 is actually used in the variable collector-resistance region of it's characteristic. And inverted. Using transistors inverted (i.e. swapping collector for emitter) often produces better switch and variable resistance results in bipolars; an old trick from back when the only devices available for variable R and switching were bipolars.
dai h.
Has thanked: 48 times
Been thanked: 12 times
Post by dai h. »
that was one of the better (sounding) DIY'ed pedals I made from the mag(where the schematic is from). I tried to figure out how to get it to go faster but only had limited success (due to my own lack of technical understanding). Oh yeah, trying an R and C in series with the battery helped to make it sound a bit more "dimensional".
Stephengiles
Post by Stephengiles »
http://www.4shared.com/dir/5287188/698a ... sound.html
This is the circuit and parts placement on the Colorsound Tremolo I had - and sold for £100!
Stephengiles
Been thanked: 124 times
Pictures linked by more cowbell are not "vintage". They are from a 90´s reissue, which - like in many cases of colorsound "90´s-reissues" - hadn´t anything in common with the original boxes except the case... an example is the colorsound tonebender Reissue - a shame for the name Tonebender:
http://analogguru.an.ohost.de/001/schem ... der_RI.gif
THe graphics shown by stephen Giles represent a "pre-75" unit. The 77 -units had 4 transistors.
MoreCowbell
Here you go AG... :)
That´s the 77 version ... to be exactly the pcb shown was produced on 10/12/77 :wink:
MoreCowbell
I should go through my gut shots gallery and see what ones might be useful....
After retracing i have to say the schematic from stephen contains mistakes:
C and E of the "attenuation transistor" are reversed (as typically for this era). and the series resistor is 1k and not 4k7 - if it is correct in the tracing.
Stephengiles
Possibly, but it's exactly as in the unit I had which worked :wink:
Stephengiles wrote:Possibly, but it's exactly as in the unit I had which worked :wink:
The part placement drawing or the schematic ?
They differ from each other.
Stephengiles
Part placement - mmmmmmmm thanks for noticing that!
bootle
Been thanked: 18 times
Post by bootle »
so just to clarify, the vintage pre-'75 unit had 3 trannies and the post '77 had 4?
is this the post '77 one?:
how many were in the 90s re-issue and how did it compare to the earlier versions?
I read there was more of a volume drop on the 90s ones.
I just built a 3 tranny version from a dragonfly vero with a MPSA13 and two 2N5089s and it's sounds pretty good.
pinio
Post by pinio »
Hello
I build simpler version this tremolo, but I'm not satisfied of his sound. Do You have printable PCB for "your" version?
I have few projects using KiCad. I will send on request :)
lmkv15
my favorite amplifier: JTM45
Completed builds: Too many
Post by lmkv15 »
here are my version that i build. (3 trannys)
regards Uwe
Colorsound Tremolo bottom.pdf
(92.43 KiB) Downloaded 299 times
Colorsound Tremolo Top.pdf
(82.45 KiB) Downloaded 265 times
ansil
my favorite amplifier: my hughes and kettner blue 30r
Completed builds: 3 jcm 800 builds
4 vintage plexi builds
2 bogner ecstasy preamps [both for personal use]
10 marshall guvnor mods and builds
100 jungle kat boosts
too many penguin love's to count.
5 blues pearl purplexed
dozen tube screamer fulldrive whatever you call them variants
hell i can't type this long it will piss off people what can i say i have been doing mods on toyz appliances gear sex toyz computers and such for 27 years. i started when i was 6 taking stuff apart.
Has thanked: 15 times
Been thanked: 13 times
Post by ansil »
have you seen the fulltone mods done on this pedal. i had mine traced out cause there was no way i was going to go crazy with this thing.
man way to many jumpers he had an unused board in this thing hadn't been populated. and built it i will have to show you the pics soon as my room mate gets up we can take some on his high res camera.
not a lot of mods on it did sub out a fet though instead one of the transistors
uncleboko
Has thanked: 58 times
Been thanked: 41 times
Post by uncleboko »
ansil wrote:have you seen the fulltone mods done on this pedal. i had mine traced out cause there was no way i was going to go crazy with this thing.
What exactly are you saying about jumpers? :roll: :roll: :roll:
sonicvi
Been thanked: 8 times
Post by sonicvi »
Pic of the original I used to own, from '77.
