MXR - 6 and 10 band Equalizer  [schematic]
Froebel
Post by Froebel »
Can I fit the linear slide resistors externally with wires
Froebel
Post by Froebel »
Hey see if this helps
I am trying to make a PCB layout with Eagle Layout Editor
MXR Schematics
MXR Schematics
Govmnt_Lacky
Post by Govmnt_Lacky »
Not to poop on anyone's parade but...
It clearly stated on the MXR schematic for the 6-band that ALL of the slider pots are:
"CTS spld taper 15K. 10% resistance at 25% rotation. 90% resistance at 75% rotation."
I see most of the diagrams that people are generating as having 50K sliders :?:
After looking at several taper curves, it appears that this taper reflects an EQ (W) taper as pointed out earlier in this thread.
Fix_Metal
Been thanked: 15 times
Post by Fix_Metal »
Govmnt_Lacky wrote:Not to poop on anyone's parade but...
6b is different than the 10b
Has thanked: 232 times
Been thanked: 888 times
Although I agree qith you that the combination of a reverse los and a log taper over the full travel, making a w-taper indeed, gives a superior response but functionally the value doesn't make a difference at all. Take 20k linears and the circuit still behaves like an EQ with the same min-max cut boost values. Make em 100k linear and it still behaves like an EQ with the same min-max cut boost values
jimosity
Post by jimosity »
On the ten band, is it possible to bypass the AC input and have it run right off of DC?
Does that mean it needs 15vDC or can it be modded to run on 9VDC (maybe with a charge pump and bipolar supply?)?
lead2203
Been thanked: 20 times
Post by lead2203 »
I have a bunch of these 15K sliders NOS from MXR if anyone need them.
Fix_Metal
Post by Fix_Metal »
jimosity wrote:On the ten band, is it possible to bypass the AC input and have it run right off of DC?
You need ±15VDC to have the same original rails.
