Krank - Distortus Maximus  [traced]
Re: Krank - Distortus Maximus
Postby ezs » 30 Sep 2011, 06:33
regarding the layout I posted above, I slightly worked it and its verified. My bass player loves it. Note orientation of chip.
ezs
Postby meffcio » 14 Jan 2013, 20:31
I have a problem with that effect. I made it using the following project:
Krank Distortus Maximus - Big Louis 22.pdf
As you can see I changed some components to, I think, scale down the tone stack. Unfortunately, when I fired this thing up, the volume control didn't shut it up completely. It was always beyond unity gain. So I changed the volume potentiometer back to 1M, but now the EQ doesn't do a damn thing. The changes in sound are so tiny, that it's really hard to tell any difference.
Can anybody tell me what's going on? :scratch:
meffcio
Have thanks: 16 times
Postby ggedamed » 14 Jan 2013, 22:11
Maybe the connection between the MID pot and the ground is broken.
ggedamed
Have thanks: 145 times
Postby A1full » 26 Oct 2013, 03:00
hi, anyone know who has this pedal impedance problems? to solve it?
A1full
Have thanks: 5 times
Postby caspercody » 19 Nov 2017, 19:01
Hello,
I made this pedal using EZS layout at top of this page. But I have some issue with getting no sound. I used a socket for the 2N5008 transistor, and when I do not have the transistor in the socket I get the following voltages:
C = 9.40
B = 0.087
E = 0.0
When I the transistor in the socket I get the following voltages:
C = 2.45
B = 0.083
E = 0.06
I double checked the resistors and for shorts, but I see nothing. Any ideas on what the voltages should read, or what to look at for the big drop once transistor is inserted?
Rob
caspercody
Has thanked: 30 times
Have thanks: 49 times
Postby Nocentelli » 19 Nov 2017, 20:32
caspercody wrote:Hello,
C = 9.40
B = 0.087
E = 0.0
C = 2.45
B = 0.083
E = 0.06
Should be a 2N5088, but any npn silicon transistor of similar spec should do, 2N5089/-3904/-2222/BC549/-108/-109/MPSA18 etc: The first stage is just an LPB-1 boost, which is pretty forgiving of exact transistor spec.
2N5008 does exist, but i think it's pretty different to what you need here, if that's what you are actually using.
Nocentelli
Has thanked: 893 times
Have thanks: 855 times
Postby caspercody » 19 Nov 2017, 23:48
Sorry it is a 2N5088 and I tried a 2N5089
Just looking for the voltage it should be at the transistor
caspercody
Postby caspercody » 20 Nov 2017, 03:25
Never mind, I found it
For this message the author caspercody has received thanks:
modman (20 Nov 2017, 11:58)
caspercody
Users browsing this forum: abfackeln, laoliang and 15 guests
