.Mike wrote:I did another layout for the CSOD, and I forgot to share it here!
Super easy build. Board-mounted pots w/ gain control, made to fit very comfortably in a 1590BB.![]()
Here are the ExpressPCB pcb/sch files and PDF toner transfer: http://www.justonemorebuild.com/project ... morebuild/
Please let me know if you build one!
Mike
agoldoor wrote:Wow Mike! Nice work! How did you manage to cut out the Overdrive part so precisely? It looks perfect, almost like it was machine-molded or something!! How did you pull that off??
Bernardduur wrote:That germanium talk on the website; wouldn't it just be a germanium diode + germanium transistor wired as a diode to provide simple hard clipping??
yeeshkul wrote:Guys has anyone measured the collector voltages on an original 18V Power Boost?
Electric Warrior wrote:Scored a Power Boost recently. Here are some photos:
[ Image ]
[ Image ]
[ Image ]
[ Image ]
[ Image ]
[ Image ]
[ Image ]
[ Image ]
[ Image ]
I restored it back to 18V:
[ Image ]
It seems like these early units came with PP4 batteries. The later ones with the PP3 clip had an additional terminal on the board where the battery clips connected with each other.
Only difference to my schematic is that it has a combination of 6.4µF, 4.7µF, 22µF and 25µF electrolytics instead of the usual 4.7µF and 22µF or 6.4 and 25µF, but no big deal.
Transistors are BC184L.
