Bogner - La Grange  [traced]
Saruman
Been thanked: 145 times
Post by Saruman »
Intripped
Has thanked: 990 times
Been thanked: 305 times
Post by Intripped »
wow, you've done a great work here! thanks!
how did you managed to remove that goop?
I see from the schem a lot of similarities with the zwex pedals (SHO, Box Of Rock, ...can you identify the transistors' numbers? bs170?), but there's also an opamp stage and hard clipping with different diodes options, which i don't recognize as a known circuit, in this moment.
Saruman
Post by Saruman »
Im Degoop Doctor :?
opamp (OPA132) K=1,5. Its boffer.
bs170 as in exampes:
Saruman
Post by Saruman »
La Grange is modified Zvex Box Of Rock.
fuzzbunny
Has thanked: 60 times
Been thanked: 14 times
Post by fuzzbunny »
:applause: Bravo!
Has thanked: 596 times
Been thanked: 2061 times
:D
What is that pic chip for ?
Intripped
Post by Intripped »
this La Grange looks like a combination of different pedals; from what i can see there is:
- a switchable BOOST section (SHO) in front
- an op-amp gain stage (if i'm not wrong the gain is 2.5, being R37(rf)=15K and R31(r2)=10K, in a non-inverting configuration)
- a modified COT50, ala Briggs, with different clipping options, "nature"="blend" and "structure"=fixed value
- a Box Of Rock with some tweaks and options
Chugs
Has thanked: 63 times
Been thanked: 47 times
Post by Chugs »
Nice work. Is there parts values for the schematic?
That op amp buffer / gain stage looks a bit weird - if it is powered by+9 and -9 volt supplies why is there an additional +9v bias rail ?
Saruman
Post by Saruman »
Only after crack Red Ecstasy Pedal. Waiting for 3 years on this forum, but why owners Red Pedl are very lazy :cry:
I buy La Grage and after 5 days I havу it scematic.
That op amp buffer gain stage looks a bit weird - if it is powered by+9 and -9 volt supplies why is there an additional +9v bias rail ?
bias rail is + 0.7V gives maximum undistorted signal on opamp
Intripped, you are absolutely right! :applause: 15k,10k
rcustoms
Has thanked: 363 times
Been thanked: 520 times
Post by rcustoms »
awesome work dude,values please to draw the pcb
guitars,pedals and amps.
@zuleta.rafael(Instagram)
Intripped
Post by Intripped »
Saruman wrote:Intripped, you are absolutely right! :applause: 15k,10k
i'm Resistor Ronker :?
...bytheway: what does ronker mean?
Saruman
Post by Saruman »
I do not know, I'm not an еnglish speaker!
FuzzMonkey
Has thanked: 44 times
Been thanked: 27 times
Post by FuzzMonkey »
Try Urban Dictionary maybe???
J0K3RX
Has thanked: 316 times
Been thanked: 556 times
Post by J0K3RX »
I think it's pretty much the British equivalent of what Americans refer to as, trailer trash, white trash, wal-mart people etc.. Definitely not a compliment.. :lol:
orcl2
Post by orcl2 »
Hi guys, nice work by the way, did you have the schem fot this?
Saruman
Post by Saruman »
to be continued.....
FuzzMonkey
Saruman wrote:to be continued.....
I look forward to it. Can I ask if the pedal still works after de-gooping it? I know they're not exactly cheap.
Saruman
Post by Saruman »
Рedal work after de-gooping. No problem.
Saruman
Post by Saruman »
