smallsound/bigsound - mini [traced]
- bubstance
Some preliminary gutshots to get things rolling. They're not the best, but it's what I can do at this precise moment. I only have the pedal for another day or two, so ask all the questions you can.
https://s44.photobucket.com/user/bubsta ... oads/story
Q1= 2N5089
Q2= J201
Q3= 2N5457
Q4= J201
Q1= 2N5089
Q2= J201
Q3= 2N5457
Q4= J201
powered by 9front
i got u. even cleaned up the schematic from the original so it's easier to read...
nah just figured i'd save everyone some time.bubstance wrote:Damn, Brian, you really are the actual fucking man, aren't you?
So what's going on in the "high gain/scramble/octave" mod on these? I've seen you offer up info for the DIY inclined, but never had a mini to look at for comparison.
uuuh let me get back about the scramble mod - i have it written down at my shop and i'm not there at the moment.
destro wrote:YES!! This is awesome. Thanks, Brian. Christmas in July!!
maybe i should make up a PCB for DIY folks?
Count me in for one. Thanks a bunch for the schematic!smallsnd/bigsnd wrote:destro wrote:YES!! This is awesome. Thanks, Brian. Christmas in July!!
- destro
.... it's a trick. Get an axe.smallsnd/bigsnd wrote:destro wrote:YES!! This is awesome. Thanks, Brian. Christmas in July!!
alright, sounds like there is interest. i'll get on it this week. the layout i use is a little weird so i'd rather make something new that's more DIY-friendly. i can make one with 2 PCB mounted pots like the way i already do it - then you wire 3 off-board pots. in my experience, a 125B is the best choice for size vs overall ease of build.
cool! oh sorry there is one small error in the schematic which is important - BIAS in the schematic is a 10k TRIMPOT.hozy31 wrote:Verified a vero layout of this on Guitar FX layouts posted by Anders in the contributions section. Awesome overdrive. Thanks Brian for the schematic.
the actual BIAS control that is panel-mounted should connect the wiper to the intersection of the drain of Q3/C4 and lug 1 to pin 1 of the 10k trim. sorry about that! you might want to update the vero. i'll update the schematic in a few minutes.
also - i use J201 for Q2 and Q4, 2N5457 for Q3.
- storyboardist
I'd socket the drain and source resistors, measure the component values and pick the values based on what 2N5457 I have. The 2N5457 has a 0.5-6V Vgs swing and Idss is 1-5mA. You'd grow old and/or broke trying to find the right through-hole JFET. My experience with SMD JFETs is they are fairly uniform so picking through them is not very productive.
nice!storyboardist wrote:Thanks Brian for sharing with us! Here's a perf and PCB layout for those interested. All pots can be board mounted and you might be able to squeeze it into a 1590B (though I agree with Brian, 125Bs are best).
that's what the trimpots are there for although you won't go broke or old if you handpick... i select all three JFETs for each pedal using a little test rig and it only takes a few minutes. ymmv though of course.EBRAddict wrote:I'd socket the drain and source resistors, measure the component values and pick the values based on what 2N5457 I have. The 2N5457 has a 0.5-6V Vgs swing and Idss is 1-5mA. You'd grow old and/or broke trying to find the right through-hole JFET. My experience with SMD JFETs is they are fairly uniform so picking through them is not very productive.
- johnk
I etched and built up storyboardist's PCB and it works great so it's verified.
what bias voltage are we looking for on the Jfet's.
I have an original 125B MINI but i'd prefer not to take it apart to measure them since the legs on them are so short.
cool! yeah it's a simple little build so it shouldn't be too difficult for anyone.johnk wrote:I etched and built up storyboardist's PCB and it works great so it's verified.
now that i think about it for Q2 i actually choose the transistor for a resistance value in my test build so that the range of the bias is correct.
for voltages, i like:
Q1 - 5.1V +/- .2V
Q2 - i go for approximately half supply at noon on the bias knob.
Q3 - 4.5-4.7V
no worries! just fyi if you change the bias points of the first and/or second jfet specifically, you may or may not have issues with the main bias knob at lower settings and/or with low bass settings.
