Behringer - BDI-21 (TB+Mids Control+ Blend Control)
goaltoday
Post by goaltoday »
This is my modded Behringer BDI21. It's a clone of the sansamp bassdriver.
Outside
Ugly Inside :oops:
Besides the true bypass I've added a mids control ( the one STM published on diystompboxes) and a new blend control. I didn't like the old blend control because the clean signal was mixed before the EQ and I want my signal unaffected.
I'll add this mods to my DIY sansamp too. So I'm going to have the behringer clone and my own clone. :lol:
Has thanked: 183 times
Been thanked: 468 times
Cool.
You should post up those mods here.
Harold
Been thanked: 21 times
Post by Harold »
goaltoday,
I can't seem to find the mid control mod you're talking about! Could you explain what to do and/or point us to the post on diystompboxes?
-tnx!-
DIY-Layout.com: Online stripboard layouts
goaltoday
Post by goaltoday »
I used this schematic
Just changed some cap values to taste.
Harold
Post by Harold »
goaltoday wrote:I used this schematic
The Bass and treble control on my Sansamp Bass Driver are quite all right as is, but I'm really interested in the mid control.
Could you post a picture of how you've implemented this schema? I'm not quite a schematics expert (yet), so I'm not quite sure what X5 is, and where to put the mid section in the sound path...
Would it also be possible to add a second potentiometer to change the freq of the mids? (semi-parametric)
-H-
samurai1993
Post by samurai1993 »
Sorry for bothering you buds, but I'm in a hurry. Last week I lend my BDI21 to a friend, and he connected it to a 9v source, but with inversed polarity. The thing heated and after a while he said it smelled like something was burnt. I checked the circuitry and all that I could found was a blowed up resistor. All in all, the pedal itself it's ok, if you use the battery input, it works ok. The problem is, I couldn't find the value of the resistor, nothing indicated on the pcb and the resistor itself was lacking any colored band coding. Could you help me? In the pcb is indicated as the R37, just at the side of the 9v input.
Thanks for your time!
Harold
Post by Harold »
samurai1993 wrote:The problem is, I couldn't find the value of the resistor, nothing indicated on the pcb and the resistor itself was lacking any colored band coding.
If it's used as polarity protection (in series with +9v), my uneducated guess is that it's only 47R or 100R.
Check this topic for more info: https://www.freestompboxes.org/viewtopic ... 79#p109979
yiye777
Post by yiye777 »
R37=330 ohm
alanamps
Post by alanamps »
I had the same problem - burnt out R37. The markings on the pcb said 330R but that didn't work - too much voltage drop across it (6.5V). I read elsewhere it should be 12R which seems a bit low. My guess it's supposed to be 33R and the pcb is marked wrongly. I put in a 22R (didn't have a 33..) and it works fine. :D
gerodoth
Post by gerodoth »
in my rev.1 pcb r37 is black and i can't see colors, but it works and tester shows 50 Ohms straight.
bdp32
Post by bdp32 »
Ancient thread I know, but R37 in my unit is a 5% 12R 1/2W easy to read the bands on that resistor even with my eyes.
Just making a note for when someone fries mine for me :) :slap:
reddesert
Been thanked: 12 times
Post by reddesert »
I also had a BDI21 (bought used) that worked on battery but not wall-wart, found that burnt component, and jumpered it with a parallel replacement. I can't remember if I used a low-value resistor or a series diode, but anything that works out to a relatively low voltage drop across it should work.
