Can I get a specially ordered reverse audio curve?
Postby psychepool » 28 Mar 2018, 10:42
I've made some stompboxes that use a reverse audio curve as a gain pot.
Crowther Audio Hot Cake, Sansamp Bass Driver, Darkglass VMT / B3K...
All of theses are have same problem.
When the drive pot is turned, the amount of gain is almost unchanged, but suddenly changes from the last 20%.
I don't compare to the original, but it seems to work pretty well on YouTube samples.
Can I get a specially ordered potentiometer that can be used for circuits with these symptoms?
It may be difficult, but it would be better if you could tell me 9mm mini pots like below because I made mini size effectors.
http://www.retroamplis.com/9mm-Knurled- ... entiometer
psychepool
Have thanks: 19 times
Re: Can I get a specially ordered reverse audio curve?
Postby grrrunge » 29 Mar 2018, 05:40
Lots of manufacturers make reverse logarithmic potentiometers. Look for reverse log, anti log, reverse audio taper etc. - they should be rather easy to find. :thumbsup
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Postby mictester » 29 Mar 2018, 10:55
You can also make your own log, anti-log, exponential, reciprocal or almost any other curve by the addition of "tapering" resistors to linear pots. There are lots of descriptions of how to do the calculations on the interweb!
For this message the author mictester has received thanks:
Nocentelli (31 Mar 2018, 23:43)
mictester
Has thanked: 32 times
Have thanks: 801 times
Postby psychepool » 29 Mar 2018, 11:06
mictester wrote:You can also make your own log, anti-log, exponential, reciprocal or almost any other curve by the addition of "tapering" resistors to linear pots. There are lots of descriptions of how to do the calculations on the interweb!
It seems a reasonable idea. Can you recommend the taper calculate tools or sites?
psychepool
Postby ppluis0 » 30 Mar 2018, 02:20
Take a read on this link: http://www.geofex.com/Article_Folders/p ... tscret.htm
For this message the author ppluis0 has received thanks: 3
95H (30 Mar 2018, 03:18), aishabag23 (30 Mar 2018, 15:17), Desdog (30 Mar 2018, 16:25)
ppluis0
Has thanked: 43 times
Have thanks: 85 times
Postby psychepool » 02 Apr 2018, 03:15
ppluis0 wrote:Take a read on this link: http://www.geofex.com/Article_Folders/p ... tscret.htm
Thank you! It will take a lot of time to read because of my bad English ability, but I will read it carefully.
psychepool
Postby POTL » 02 Apr 2018, 22:55
The easiest way to use an ordinary logarithmic potentiometer is by simply swapping 1 and 3 legs.
You will get a reverse logarithmic potentiometer, just it will work in the opposite direction.
POTL
Has thanked: 65 times
Have thanks: 60 times
Return to Parts Sourcing & Trading
