Wampler Sovereign Distortion  [traced]
Re: Wampler Sovereign Distortion
Postby MoonWatcher » 25 Jul 2016, 23:50
Bloodman wrote:I have already traced this pedal
Please post your schematic from your tracing.
MoonWatcher
Has thanked: 43 times
Have thanks: 63 times
Postby Bloodman » 26 Jul 2016, 05:22
I'm a Chinese, this may take a little time to sort out my documents.I want to write something here recently about this pedal .as you know,maybe I need to translate my idea to english
Bloodman
Has thanked: 13 times
Have thanks: 34 times
Postby 287m » 26 Jul 2016, 17:27
Bloodman wrote:I'm a Chinese, this may take a little time to sort out my documents.I want to write something here recently about this pedal .as you know,maybe I need to translate my idea to english
we always wait you
and i think for almost member here, the language of your idea is just scheme only, explanation later :secret:
287m
Has thanked: 306 times
Have thanks: 56 times
Postby J0K3RX » 26 Jul 2016, 18:37
Bloodman wrote:
MoonWatcher wrote:
Bloodman wrote:The monolithic circuit and parameters of the sovereign are very similar with the pinnacle
Indeed. It seems that there are a bit of similarities, in particular, with it and the Pinnacle LE. The latter was traced out in what I think was a Pinnacle II thread. So I went and dropped in the capacitor values for the LE, and then looked at the Sovereign. I tried to label what I thought might be the cap equivalents.
I figured that until someone has one to trace, that the next step would be figuring out the resistor values, and then they could be cross-referenced to the Pinnacle as well.
This seemed like as good a place as any to start. I hope it helps.
J0K3RX
Has thanked: 320 times
Have thanks: 490 times
Re: Wampler Sovereign Distortion  [traced]
Postby Bloodman » 28 Jul 2016, 12:41
:popcorn:
I don't know how to upload the PDF file
For this message the author Bloodman has received thanks: 19
bluesaxe (04 Sep 2016, 23:20), Intripped (28 Jul 2016, 12:51), IvIark (13 Sep 2018, 23:33), Manfred (28 Jul 2016, 17:44), moon-ra (22 Apr 2017, 21:35), nexion777 (24 May 2017, 14:21), oh7hhi (31 Aug 2016, 15:39), roseblood11 (16 Aug 2017, 23:16), suzukiscottie (01 Aug 2016, 06:16), tcpoint (06 Jun 2018, 16:38) and 9 more users
Bloodman
Postby mlp-mx6 » 28 Jul 2016, 12:44
In the right tab below the text box it says "Upload attachment" - use that.
mlp-mx6
Have thanks: 3 times
Postby Bloodman » 28 Jul 2016, 12:49
mlp-mx6 wrote:In the right tab below the text box it says "Upload attachment" - use that.
Thanks ,I got it
Bloodman
Postby Bloodman » 28 Jul 2016, 12:55
This is the second version of Pinnacle
For this message the author Bloodman has received thanks: 5
287m (31 Jul 2016, 16:35), downboyblues (30 Jul 2016, 11:29), J0K3RX (28 Jul 2016, 19:01), modman (28 Jul 2016, 13:06), rbstep (30 Jul 2016, 02:03)
Bloodman
Postby mwelch55 » 15 Sep 2017, 19:54
Referring to the schematic posted last year, does anyone know the purpose of the MOSFET in the power section of the schematic? I have never seen that before.
Mike
mwelch55
Postby POTL » 16 Sep 2017, 00:33
Mike
Hi
this is reverse polarity protection
For this message the author POTL has received thanks:
mwelch55 (18 Sep 2017, 15:05)
POTL
Has thanked: 65 times
Postby Ice-9 » 25 Sep 2017, 23:23
I pretty much use that Mosfet polarity protection in most of my builds. You can read how it all works on R.G's Geofex site.
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Postby ray86 » 01 Jun 2018, 16:30
sound great !!!
ray86
Postby annaelyse_win » 12 Sep 2018, 20:43
Recently picked up a broken Sovereign for free from someone.
However, some parts were taken out of the circuit and the pedal dissembled.
I've managed to replace the missing parts and attach the input, output, and power supply correctly..well...hopefully.
Can anyone give advice on how the original schematic wires up the foot switch and input and outputs?
annaelyse_win
Postby Bloodman » 31 Dec 2018, 16:33
annaelyse_win wrote:Recently picked up a broken Sovereign for free from someone.
This schematic is the original pedal that I duplicated, but as far as I know, there are many versions of the pedal circulating in the market.it is difficult to determine whether the circuit you see is consistent with what I see.
Hope to be of use to you,Forgive my poor English
Bloodman
Users browsing this forum: clash67, Iconnu, ppfai, rlw1138, sopapo1, The Rotagilla, v0d00blues79 and 20 guests
