Rams Head Big Muff 2N5133, FS36999 hFE notes
Postby solderman79 » 02 Jan 2019, 02:26
A few years ago I posted the actual hfe of Q1-Q4 from a 1974 Rams Bead Big Muff with FS36999 transistors as measured using a Peak DCA55. They were: Q4: 163, Q3: 214, Q2: 171, Q1: 160.
Since that time I've worked on three more pre-1975 Rams Head Big muffs. Two had FS36999 trannys and one had 2N5133 trannys. Guess what...they all measured less than 200 hfe, lol. The one with 2N5133 trannys were as follows: Q4: 132, Q3: 117, Q2: 145, Q1: 128. I also noticed Kit Rae posted some of his own measurements on his site: "When I pulled all four FS36999 transistors from an exceptional sounding 1973 Big Muff and measured the hFE I found it ranged from 164 to 204 (Q1: 164, Q2: 204, Q3: 183, Q4: 161)."
I guess my point is this; I bet the majority of the "holy grail" big muffs from the 1970s have low hfe trannys. Remember just a few years ago when everyone on the internet was swearing up and down that you needed unobtainable vintage 2N5133 trannys with hfe of 500+ to get a magical muff. I think that is just a myth. Everyone said that less than 200 hfe resulted in mud. I have found the opposite seems to be true on my socketed test board using the so called "1973 v3 or violet schematics". While the difference is subtle, to my ears lower hfe (under 200) has the effect of decreasing low end boominess and increasing clarity at the expense of a very slight loss in overall saturation.
Also, in my opinion most of the recorded BMP sounds from DG don't really sound all that high gain and aggressive if you listen carefully, but rather they are very focused, clear, and present. Certainly everyone agrees DG has recorded some of the most beautiful Big Muff sounds ever known to mankind.
Sorry, I seem to have made a rather long post, but the lore and mystic of vintage big muffs intrigues me. lol.
For this message the author solderman79 has received thanks: 3
bmxguitarsbmx (02 Jan 2019, 04:51), Intripped (02 Jan 2019, 02:36), lolbou (07 Feb 2019, 13:12)
solderman79
Have thanks: 28 times
Re: Rams Head Big Muff 2N5133, FS36999 hFE notes
Postby bajaman » 02 Jan 2019, 02:34
I think all those early EHX designs used the cheapest end of line components that they could find - not surprised that the transistors were low gain - lol.
Has thanked: 448 times
Have thanks: 1543 times
Postby mictester » 02 Jan 2019, 11:01
That's why I always build the BMP using a CA3046 transistor array these days. The hfe of the devices are always around 150 - 180. This "Fuzz Chip" (thanks Lance!) is also great in the old SuperFuzz and Fender Blender circuits - especially where you need accurately matched transistors for the frequency-doubling aspect of the circuit.
If you build your "Ram's Head" BMP with a CA3046, you'll get a great sounding pedal. I have used the "spare" transistor to add an optional bootstrapped buffer / pre-amp stage before the input of the main effect. This gives proper buffered bypass. The board layout is very small (and single-sided), and can be built in about 15 minutes if you have the parts on hand. If you use the Omeg sealed cermet pots, a good quality footswitch, use rubber goop over both sides of the PCB and good quality connectors in a good quality diecast box, you'll end up with a very robust, waterproof pedal that will withstand the rigours of life on the road!
For this message the author mictester has received thanks: 3
Chappy (07 Jan 2019, 18:33), solderman79 (03 Jan 2019, 01:13), thetragichero (02 Jan 2019, 15:04)
mictester
Has thanked: 33 times
Have thanks: 804 times
Postby aionios » 02 Jan 2019, 15:43
Thank you, this is great research! I've always preferred 2N3904s (150-200) to 2N5088s (350-450), but without any research backing me up on it. Sounds like the 3904 is closer to the real thing for the most part.
mictester wrote:That's why I always build the BMP using a CA3046 transistor array these days. The hfe of the devices are always around 150 - 180.
In my own experience, the through-hole CA3046's I've measured have been way down at the low end of the datasheet's listed Hfe range, around 40-50. I also tested about a dozen SMD LM3046's that were all in the 60-90 range, and a handful HFE3046's that were all in the 50-60 range. I've never seen one of any 3046 variety that tested above 100.
My total sample size is only about 25, so I don't mean this as any sort of blanket statement – but it's enough that I wouldn't trust any chip without measuring it first if I was using it in a circuit that didn't handle super low Hfe very well (for example the Superfuzz & BMP).
Aion Electronics - DIY PCB projects for classic and obscure circuits
aionios
Have thanks: 54 times
Postby Cub » 07 Jan 2019, 08:38
mictester wrote:If you build your "Ram's Head" BMP with a CA3046, you'll get a great sounding pedal. I have used the "spare" transistor to add an optional bootstrapped buffer / pre-amp stage before the input of the main effect. This gives proper buffered bypass.
Sounds neat! That spare transistor could also be used as a booster, similar to the the Blackout Effectors Musket Fuzz and a couple of other recent Muff clones. Then an opamp wrapper, as on your 21st Century Big Muff, can take care of the buffering.
Did the CA3046 Ram's Head replace the 21st Century Big Muff as your main Muff build, or is it an added flavour?
Cub
Has thanked: 75 times
Have thanks: 88 times
Postby digi2t » 09 Jan 2019, 13:01
Insofar as array chips are concerned, MPQ2222 are my preferred. This applies not only to BMP's, but Superfuzz as well (with a 2N2913 in the octave section). Consistently within a 150 to 200 gain range, they do a wonderful job of pushing the amp without being obnoxious.
If I want a Muff that's loud, with lots of buzz saw presence, then I'll defer to a set of BCY 59X transistors. Haven't found any transistors with more cojonas than these yet.
No matter how many times I cut it, it`s STILL too short!
digi2t
Has thanked: 56 times
Have thanks: 356 times
Postby luix » 06 Feb 2019, 18:19
solderman79 wrote:I guess my point is this; I bet the majority of the "holy grail" big muffs from the 1970s have low hfe trannys.
Yes, I agree with your opinion, the best muffs I've build up was that with BC134 "dome top" transistors and they have hfe between 150 and 200.
luix
Postby lolbou » 07 Feb 2019, 13:17
mictester wrote:This "Fuzz Chip" (thanks Lance!)
:lol: This one brought a large smile...
It's really nice to kill the myth indeed. I've got some nice "dome-top" Fairchild 2N5134 (i think it's this close to the original number), i'd better measure them to try it...
Anyway, the Fuzz chip advice definitely sounds like a good one indeed!
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 352 times
Have thanks: 240 times
Postby Abyz0u » 01 Mar 2019, 18:17
ive never tried it but in theory even 2n2222's should work just fine since muff clips the signal in 3 stages meaning with 50x gain on each stage we end up with 125000x overall gain which is way more than enough hence super high gain trannys becoming kinda useless.
however AFAIK its impossible to achieve such numbers in reality(c-b feedback gain loss,leakage etc.)
Abyz0u
Postby 666scorpions » 02 Mar 2019, 22:59
I'm really happy to find this post while l was searching for something completly different infos...
I'm a pedal builder and fixer from France and I have just noted the same as you when I've fixed some old Big Muffs units.
Last time I measured an 70's era BMP with some 2N5133 (never had a FS36999 one in hand), my Beta's were Q1:177/ Q2: 204/ Q3: 197/ Q4; 169
So I had the same conclusion, Ram's head and Violet Era sweetness sound comes partly from really low and yes cheap transistors.
Remember that Electro-Harmonix's CEO is a
big money saver (is it english word? Don't know...), so for him cheap is good.
Another technical info that I've noted is that when you put around 200hfe transistors in a Big Muff circuit you get really close to 4.50volts voltage for the collector and
if you put 500/600hfe trannys you get more close and sometimes less than 4.00volts. So I think that those 10k/12k collector resistors was thoughts for low hfe trannies....
I had an another revelation when I heard the best Big Muff ever for me, she was full of dirt cheap 25volts brown ceramic capacitors, far away from audiophilia's theory...
And maybe logical if you think a fuzz as an audio signal destructor and not an Hi-Fi clinical emitter.
The ones saying 500+ hfe is the best are the same forum's parrots saying that JRC4558 is best in Ibanez TS808, 4558 was the more common AOP of the beginnig of the 80's because it was the cheapest, you can find it in virtually every alarm clock from that era.... but maybe alarm clock got that "vintage brown sound" that every good guitarist is looking for.... don't know.
More seriously I think the mistake begin when people thinks "I want a big ass fuzz so I need a LOT OF GAIN so I need A LOT OF HFE."
It's a classic misunderstood... Furthermore the lower Hfe you have the best low frequencies passing (body of the sound) you get, that is a good point when you build a raspy trebly fuzz.
And even the trannies classified Hfe categories (A/C/B) from now and from the 70's is not the same. A BC239c coming from a 1977 big muff will be maybe 300 to 400Hfe and if you buy a BC550c now, so an High gain/Low noise transistor as BC239c, you can easily find more 500+Hfe. So when in 2019 we are saying that a 2n2222 is pretty low gain with its 196Hfe we can decently say that a guy from 1974 was thinking that this same transistor has a good amount of gain.
So now when I build Ram's head I use some 70's ITT 239B and 239 handselected around 200/220 in a range of 180 to 350 Hfe. I found a good amout of them and I'm glad of how it sounds.
Glad to find other people finding the same things.
Cheerz from france
E.
666scorpions
Postby lolbou » 03 Mar 2019, 15:10
lolbou wrote:I've got some nice "dome-top" Fairchild 2N5134 (i think it's this close to the original number), i'd better measure them to try it...
Been in the parts drawers, and i happen to have NOS Fairchild 2N5133, measured from 160 to 250. :D I guess a clone is on its way...
The NOS FS 2N5134 i have here are 230-250ish... Might worth a try as well!
Thanks for the input 666scorpions! :wink:
lolbou
Postby luix » 08 Mar 2019, 09:15
You should also try carbon comp resistors, at least in the collector position, I've not measured anything but I think that they add some sort of distortion.
Those resistors are the only components (transistors apart) that have influence on the sound taste, I've tryed any kind of capacitor experiencing no difference in the sound.
luix
