Baja Active EMG Schematic
Postby Rauch » 08 Jul 2019, 18:53
Hi I want try out the Baja active pickup system did anyone are use it ? İts good ? So can anyone post schematic please ?( not trace file) thanks :D
Rauch
Re: Baja Active EMG Schematic
Postby bajaman » 08 Jul 2019, 22:43
google is your friend :wink:
https://www.electrosmash.com/emg81
scroll down 8)
Has thanked: 459 times
Have thanks: 1585 times
Postby Rauch » 09 Jul 2019, 09:05
bajaman wrote:google is your friend :wink:
scroll down 8)
I know the site but cant see schematic before my bad sorry I cant find the MMDB701 Diode. Have any replace for it
Rauch
Postby EddieTavares » 09 Jul 2019, 13:17
Rauch
This diode does nothing to the signal, it is only reverse power flow protection so you can use anyone.
EddieTavares
Have thanks: 17 times
Postby Rauch » 09 Jul 2019, 17:45
EddieTavares wrote:Rauch
Ex. 1N4148 ? Thanks
Rauch
Postby EddieTavares » 10 Jul 2019, 15:34
Yes, it'll work perfectly!
An option something better is to use an schottky diode, anyone. There is a little voltage drop (aprox. 0,6v) when 1N4148 is used in this way, it does not affect your tone when the battery is fully charged.
Another good Idea is to use it in parallel as it is used in pedals.
EddieTavares
Postby Rauch » 11 Jul 2019, 18:32
EddieTavares wrote:Yes, it'll work perfectly!
I found mmbd diode footprint and add it bit I cant understand one thing 4205 pin 4 ground and pin 7 to 9v+ is it ? Or something else ?
Rauch
