Seymour Duncan - Tweak Fuzz  [schematic]
Postby analogguru » 26 Jun 2007, 15:56
Here is the:
Seymour Duncan Tweak Fuzz schematic
enjoy,
For this message the author analogguru has received thanks: 2
Blitz Krieg (17 Mar 2016, 07:02), stilwel (16 Mar 2016, 16:11)
Have thanks: 116 times
Postby modman » 04 Sep 2007, 00:35
Has thanked: 3092 times
Have thanks: 534 times
Re: Seymour Duncan - Tweak Fuzz
Postby lynessmy » 14 May 2008, 09:24
How are them compared? The link doesn't work...
lynessmy
Postby BeAR » 17 May 2008, 08:59
Thanks to analogguru, I just built this stomp box. Schematic is spot on and sounds killer too!
Hope these help others. The ceramic on the bottom of the board just parallels up the 22pf on the top of the board as I didnt have a 47pf lying around.
BeAR
Postby BeAR » 19 May 2008, 01:54
Just another quick update if anyone cares, Ive been playing around with the 2 transistors in the tweak fuzz and Ive found a better combination . Q1 is now a BC550 and Q2 is a BS170. This gives a tighter more focussed fuzz without the wooly bottom end when the tweak knob is wound arount to the 2.2uf cap.
BeAR
Postby marshmellow » 19 May 2008, 10:42
A BS170? You replaced a bipolar transistor with a switching MOSFET??
marshmellow
Has thanked: 13 times
Have thanks: 114 times
Postby flood » 19 May 2008, 12:40
marshmellow wrote:A BS170? You replaced a bipolar transistor with a switching MOSFET??
:scratch: +1
holy p-n junctions, batman!
flood
Have thanks: 17 times
Postby lynessmy » 20 May 2008, 02:55
What a nice PCB from BEar. I gonna make this PCB.
In fact, I had drawn one and tried on the weekend. But it doesn't work.
With the audio probe, i found that there are no signal passing thru the selectable CAP, no matter in which position.
Can anyone help me to understand what went wrong? I didn't pop in the 1M pull down resistor.
lynessmy
Postby BeAR » 20 May 2008, 22:41
Yeah I know, strange but it works a treat. There is a discussion in the Workbench section about it. Some fets seem to bias just right as a direct replacement. As I said in that post, it shouldnt work, but it sounds better than any other option Ive tried.
BeAR
Postby iggy23 » 23 May 2008, 21:52
has somebody a vero layout???? :roll:
iggy23
Postby B3ar » 23 Dec 2010, 01:37
I got a good deal on a new Tweak Fuzz and am quite pleased with the implementation of SMD -- there are through-holes next to the SMD transistors and resistors, while the caps are already through-hole. Cheap to manufacture, easy to mod -- thanks, guys!
Folks mention that since it's a FF, mod accordingly, and apparently there's a popular easy variant on the Roger Mayer "volume" mods out there. (Remove R5, change R4 to 8k2.) I'm going to try some of the standard value tweaks over on R.G.'s Geofex page, especially those that are just resistor changes.
But I wanted to ask whether anyone has sub'ed out the stock SMD transistors, and whether it was particularly life changing. This is my first FF and I'm not unhappy with the base tone, but I want to be sure I'm not missing the boat.
B3ar
Has thanked: 29 times
Have thanks: 4 times
Postby holgar » 24 Mar 2014, 12:34
Thanx for the shem,
this Fuzz Face got the right name, because it is so easy to tweak.
For some more volume I lifted R4 to 1K. For biasing Q2 I took 10K at R5 (4,8V).
Instead of the useles C5 120n I took a Mullard 0,022uF, because I was missing a position 2,5 on the Tweak knob.
Of course the Mullard mojo oozes now through the whole circuit ;-)
For this message the author holgar has received thanks:
ljn (16 Mar 2016, 10:18)
holgar
Postby biglouis » 02 Apr 2015, 22:49
Does anyone have the schematic?
The analogguru link is offline.
biglouis
Postby LooseCannon » 04 Nov 2015, 10:48
Same question here.
LooseCannon
Has thanked: 10 times
Postby karul » 04 Nov 2015, 13:21
here it is
For this message the author karul has received thanks: 2
Blitz Krieg (05 Nov 2015, 08:58), LooseCannon (04 Nov 2015, 17:13)
karul
Has thanked: 216 times
Have thanks: 143 times
Postby LooseCannon » 04 Nov 2015, 17:13
LooseCannon
Postby stilwel » 16 Mar 2016, 05:38
FYI....I believe Q1 and Q2 are mislabeled in the schematic. If you trace out the circuit, Q2 on the PCB is actually the input buffer transistor.
I have 2 Tweak Fuzz pedals here, both have Rev A PCBs. Maybe they changed it on a later revision?
Anyway, I'm in the process of looking for some BC183 BC183C transistors for this beastie and discovered this tonight...thought I'd share.
stilwel
Postby ljn » 16 Mar 2016, 10:19
I just tried the resistor values suggested by holgar on my tweak fuzz. It sounds better than ever.
ljn
Have thanks: 8 times
Users browsing this forum: Brainbender, Google Feedfetcher, ltdf50 and 11 guests
