TL072 & TL062
- Gila_Crisis
can someone tell me the difference between the TL072 and the TL062??
the fact is that i'm modding a bit my Boss Flanger and i wanna change the 2 4558. i know a guy that as putted in a TL072 for IC1 and a TL062 for IC2.
What's the difference?
also i was thinking about 2 NE5532 instead, will those also work? do you think this is a better choise?
thank you
thank you
- briggs
I think the 072 is a more "HI-FI" version of the 062. I havn't seen the schematic of the boss flanger in question but I would guess that one of those op amps is used as a lfo - there would be no point in changing this one as it isn't in the audio path... The NE5532 is a low noise opamp, I would change the opamp that is in the signal path to one of them.
- Gila_Crisis
- briggs
- Gila_Crisis
ok thank you
- Gila_Crisis
thank you too mayniac as well! this is what i was trying to know!
but i'll think now i'll go with 2 NE5532 (is right to think that the 5532 is better than the 072?)
- bajaman
- Has thanked: 596 times
- Been thanked: 2061 times
Just woke up
Mayniac is correct, BUT, I always thought the 062 was a low current version of the 072, not the 082.
Because it is a lower current device, it is a lot smoother sounding when used in gain stages, due to the much lower slew rate at high frequencies.
James Demeter uses one in his Tremulator pedal, and it is a very low noise and very smooth sounding unit.
With regards to the NE5532 - it draws considerably more current than even the 072 and 082 devices - your battery will last 10 times longer with the 062 device , also, they are not a high impedance input device like the TLxxx devices - I am not a great fan of them - they can be very useful as line drivers though, due to their ability to drive 600 ohm loads with ease . I hate them used as microphone input stages though - they make everything sound flat and sterile due to their low impedance damping of the input signal
- Gila_Crisis
the current isn't a problem for me, 'cause i always use an adapter for all my pedals.
you personally what do you think is better now in my case?
- modman
- a d m i n
- Has thanked: 4411 times
- Been thanked: 2139 times
I'm of the same opinion, tried recharging alkaline 9Vs with mixed success. How can you justify paying so much money on batteries for the reliabilty that they provide?
A lot of guitarist stick to them, I know, but you really want to unscrew that hammond box? On a Boss it's real easy! I've read serious people swearing by them as well, but personally never had problems with adaptors.
All 061 are soundwise total crap, but they draw only 1/10 of the current of a 071. The Boss flanger sucks a battery out in 2 hours even with the 061s in it.
I would replace all 061 with TI TL071 and run the pedal with a 9/10V DC-supply.
JHS
JHS
- markm
Personally, I like batteries but, part of that is being old-school!
NE5532, never heard them in anything that really sounded good to my ears......kinda "sterile" to me?
Join together with the "Banned"!
- MoreCowbell
- Transistor Tuner
I've had good results with the OPA2604
- bajaman
I disagree here - unless you demand too much voltage gain from them - under 10db gain (3x) they are fine to my ears.All 061 are soundwise total crap
I agree here, BUTthey do make good line level drivers when run off +/- 15v (or higher) supplies.NE5532, never heard them in anything that really sounded good to my ears......kinda "sterile" to me?
it is a case of "horses for courses"
- Gila_Crisis
ok then i'll put in 2 TL072 and make it over like that!
thank you all
thank you all
