Roland - AP-7 Jet Phaser  [schematic]
Postby modman » 17 Sep 2007, 08:47
Aharon contributed this PDF from the service manual containing pcb layouts, block diagram and construction notes.
Roland AP-7 Phaser service notes
thanks so much for sharing!
Has thanked: 3267 times
Have thanks: 608 times
Postby Aharon » 19 Sep 2007, 20:55
Welcome !!!
Maybe somebody can figure out the off board wiring,I couldn't.....
Aharon :oops:
For this message the author Aharon has received thanks:
modman (07 Jan 2018, 12:35)
Aharon
Has thanked: 24 times
Have thanks: 8 times
Postby analogguru » 04 Dec 2007, 22:17
OK, Aharon: you want to figure out the offboard-wiring ?
Have a look here, but: caution that you don´t get nuts, from the highres guts:
http://img148.imageshack.us/img148/9421/jp1dm9.jpg
http://img148.imageshack.us/img148/579/jp2on7.jpg
http://img520.imageshack.us/img520/6397/ph3ui2.jpg
http://img520.imageshack.us/img520/5964/ph9fw5.jpg
http://img504.imageshack.us/img504/2210/ph10lc4.jpg
Could you smell the vintage electronic ? :wink:
Have thanks: 116 times
Postby Aharon » 05 Dec 2007, 04:30
Thanks for those shots analogguru!!!!!!
Snifffffffffff........yes I can smell the old electronics.........ahhhhhhh......
Aharon
Aharon
Postby MrHuge » 09 Dec 2007, 21:25
Wow! how things travel on the net... That looks suspiciously like the copy of the AP7 schematic I scanned! Cool...
Here are more...
http://www.aronnelson.com/gallery/v/MrHuge/album102/
-Mr. Huge
For this message the author MrHuge has received thanks:
modman (29 Aug 2011, 14:37)
MrHuge
Have thanks: 45 times
Re: Roland - AP-7 Phaser
Postby Stompmodder » 09 Jul 2008, 14:11
modman wrote:Aharon contributed this PDF from the service manual containing pcb layouts, block diagram and construction notes.
Just wondering if someone have the schematic of this pedal. Thanks
Stompmodder
Have thanks: 5 times
Postby IggY » 09 Jul 2008, 15:16
Just read this thread one more time to stop wondering.
IggY
Postby Bernardduur » 09 Jul 2008, 16:03
Can someone tell me why this unit sounds so good on bass? I've tried (too much) phasers on bass but this was the only one that stood up my abuse / thoughts on how one should sound on bass.
Great unit btw!
Bernardduur
Has thanked: 87 times
Have thanks: 489 times
Postby Bernardduur » 09 Jul 2008, 18:50
I was looking into this subject now for a long time; need to build one for my bass use (as does Larry Graham)
There are 4 JET settings, 2 non jet setting and a fast / slow setting on which only the slow speed can be set by a potmeter
1 and 3 JET give shallow modulation (depth is determined by point 10 / 12)
2 and 4 JET give a deep modulation
Difference between 1-2 and 3-4 are the JET EQ; one has mids, one lacks it.
5 and 6 are just shallow and deep modulation without the JET
You can make these changes more easily switchable with individual switches.
Bernardduur
Postby littleBloona » 10 Jul 2008, 00:39
Bernardduur wrote:Can someone tell me why this unit sounds so good on bass? I've tried (too much) phasers on bass but this was the only one that stood up my abuse / thoughts on how one should sound on bass.
Great unit btw!
What a difference two diodes can make :arrow:
littleBloona
Have thanks: 2 times
Postby chicago_mike » 10 Jul 2008, 12:49
I get a 4040 error when trying to see the gut shots..can some one pm them to me or email me the gut shots?
Or are they uploaded elsewhere?
Skyline FX 2013
chicago_mike
Has thanked: 23 times
Have thanks: 302 times
Postby lynessmy » 25 Jul 2008, 10:33
I have the TRACE side...downloaded from somewhere...but no component side.....
lynessmy
Postby chicago_mike » 29 Jul 2008, 05:41
Ill take it. :) Im itchin to clone this thing. Larry Graham uses this to great effect. 8)
Skyline FX 2013
chicago_mike
Postby analogguru » 29 Jul 2008, 07:37
chicago_mike wrote:Ill take it. :) Im itchin to clone this thing. Larry Graham uses this to great effect. 8)
Are you really that greedy, man ? :wink:
Ok, here you go for the track side..... and as a "bonus track" you will get the component side too, taken by ebay user "coastal.a.a".
Postby NoGlory » 14 Mar 2009, 13:03
Does somebody maybe have a PCB layout? I'm going to clone this thingy, but the less the work, the better :applause:
NoGlory
Postby lynessmy » 13 Apr 2009, 04:27
NoGlory wrote:Does somebody maybe have a PCB layout? I'm going to clone this thingy, but the less the work, the better :applause:
This is all i have. NO layout.
Let me know if you manage to work this out.
Again, this is downloaded from somewhere which i couldn't recall now. If anyone know where is the origin, give him a credit.
For this message the author lynessmy has received thanks: 2
modman (09 Aug 2019, 10:20), pedalgrinder (31 Mar 2013, 12:53)
lynessmy
Postby chicago_mike » 15 Apr 2009, 18:34
Hey....
What size do I need to alter this too, so it doesn't print out a full page sized pcb? I hope to get this etched today. :)
Skyline FX 2013
chicago_mike
Postby lynessmy » 19 Apr 2009, 16:17
use the width of the DIL IC....the distance between 2 rows is 7.5mm. Scale it....
lynessmy
Postby chicago_mike » 27 Oct 2009, 03:05
Okay i printed this out but it came out all fuzzy..I forgot its at 72dpi resolution...TERRIBLE.
So I resized the image to 5.5inches..letf the constrain portions on, 5.5 inches mind you. ANd set resolution to 1200 dpi.
I think I did the resolution first though. Did a little cleaning up with levels (photoshop again)
now I think it should print nice and clear. Still at 1200 dpi though normal 8.5x11 is 300 dpi. So just a little more adjusting and we have ourselves a rpintable pcb of the jetphase.
Now there IS a second board but I think thats for the speed control, and just a few components I can do on a breadboard, or vero or whatever. :)
next step is to be able to print 2 on a sheet of photopaper..or some cheap glossy paper that will still dosolve in water. I want to try to find a mixture of something that will help disolve the paper but leave the toner....
Skyline FX 2013
chicago_mike
Postby lynessmy » 30 Oct 2009, 10:01
Hi...chicago_mike....i was a noob at the resolution thingy.
Appreciated if you have some guide or any link to share to get thru that, especially how to play with PHOTOSHOP for RESOLUTION and SIZE.
TQ
lynessmy
Next
Users browsing this forum: AnalogPackrat, DGWVI, Jakn, nickelx and 6 guests
