HH electronics - Clockwork Concubine  [schematic]
Postby Dirk_Hendrik » 05 Oct 2008, 16:34
I could have bumped an older topic but prefer a new one.
The concubine has been discussed but it does not seem that people have hands on experience playing the thing. Not so strange since it needs to be connected to an HH amplifier (which I don't have) in order to be powered and get signal.
I've reversed one but expect more errors to show up. The design topology is everything but conventional, as an example.
However, here's the job so far. It's a flanger and uses a SAD1024. Other than that there's little similatities to the Mistress.
http://www.dirk-hendrik.com/temp/clockwork_concubine.pdf
For this message the author Dirk_Hendrik has received thanks: 3
akestromer (03 Aug 2017, 02:38), modman (24 Apr 2015, 08:40), Stasss (08 May 2018, 09:08)
Has thanked: 255 times
Have thanks: 1036 times
Re: HH electronics Clockwork Concubine
Postby DiscoFreq » 05 Oct 2008, 19:10
Great! :D
So can you tell me how to make an adaptor cable for audio in, audio out and power? :D
(if I can find a connector that fits...)
EffectsDatabase: http://www.effectsdatabase.com
22000 pedals, 4000 brands, 350 brand interviews
NAMM 2016: http://fxdb.org/namm
DiscoFreq
Have thanks: 26 times
Postby theehman » 06 Oct 2008, 13:55
Dirk_Hendrik wrote:I could have bumped an older topic but prefer a new one.
I think I have the actual HH schematic for this. I bought a service manual a couple of years ago when I got my Clockwork Concubine.
Ron Neely II
fx schematics and repairs
theehman
Has thanked: 86 times
Have thanks: 87 times
Re: HH electronics - Clockwork Concubine
Postby Bernardduur » 10 Oct 2008, 08:36
I have a HH amp if something of that is needed.......
Bernardduur
Has thanked: 87 times
Have thanks: 490 times
Postby DiscoFreq » 10 Oct 2008, 08:52
Bernardduur wrote:I have a HH amp if something of that is needed.......
I could use information about the pins in that cable if you know something about that...
DiscoFreq
Postby Bernardduur » 10 Oct 2008, 14:26
I'll check when I am in the rehearsal room tomorrow!
Bernardduur
CLOCKWORK CONCUBINE Confusion
Postby fritz-empit » 27 Dec 2008, 08:34
hi dirk ,how are you
im fritz from jakarta...your website is brilliant
and everybody here would help me
i've just got a HH CLOCKWORK CONCUBINE
i really have no idea about where the one of the guitar input jack ?,where the one of output jack ?and where the power supply socket jack i used to call....?and how big voltage needed to operate this pedal ? 9 / 12 volt adapter or 110 / 220 volt ?
i really really need your helped to tell me how to use this pedal correctly :(
thanks ,GBU ,have a nice day
best regards ,fritz
fritz-empit
Postby Bernardduur » 27 Dec 2008, 12:08
Hmmm, forgot to reply.
Searched the amp but I can't differ it from the outside. When my guitarist uses my new build amp I'll check out his HH!
Bernardduur
Postby bajaman » 27 Dec 2008, 12:44
Hi Dirk - I have several factory HH schematics - what model of HH amplifier were these Clockwork Concubines used with??
Has thanked: 461 times
Have thanks: 1591 times
Postby Dirk_Hendrik » 27 Dec 2008, 18:40
:oops:
No clue... The Clockwork Orange is the only HH product I have.
Postby fritz-empit » 02 Jan 2009, 19:16
fritz-empit
Postby theehman » 02 Jan 2009, 19:55
Not the best quality, but this should help. This came from my H&H Service Manual.
Ron Neely II
For this message the author theehman has received thanks: 3
akestromer (03 Aug 2017, 02:38), lasermonkey (07 Jan 2018, 12:18), modman (24 Apr 2015, 08:39)
theehman
Postby Dirk_Hendrik » 02 Jan 2009, 22:46
Thanks Ron!!
Poor quality scan indeed but with my drawing and the real thing here I should be able to fill in the blanks. Much appreciated!
Postby lasermonkey » 21 Apr 2013, 21:53
Just scored one on eBay! When it arrives I'll take some gut shots and try to work out some kind of interface box.
lasermonkey
Has thanked: 34 times
Have thanks: 18 times
Postby Professor SourTone » 23 Apr 2015, 18:01
Here are some innards.
This pedal is quite tricky to dismantle...
http://smg.photobucket.com/user/spangle ... t=6&page=1
For this message the author Professor SourTone has received thanks:
Professor SourTone
Have thanks: 42 times
Postby Professor SourTone » 13 May 2015, 20:58
It works. I think the cable is the original one, too.
Sort of OK, but much prefer the E.Mistress. Would be interesting into a valve amp - there's a line out on the IC100 so could try that. It does a kind of rotary speaker thing, the metallic stuff, but not much else. The reverb switches on and off ok but again the reverb itself is so-so
The amp would be ok for spiky rhythm work, which is why I guess Bolan and Wilko Johnson liked them.
http://img.photobucket.com/albums/v208/ ... orehdo.jpg
http://img.photobucket.com/albums/v208/ ... aelbzo.jpg
Professor SourTone
Postby Professor SourTone » 14 May 2015, 13:19
Professor SourTone
Postby akestromer » 03 Aug 2017, 02:37
Has anyone here figured out the voltages on these things?
I got one over 10 years ago and started looking for the schematic, emailed the maj electronics people but never heard back. I had given up until I saw this thread.
akestromer
Postby rs » 12 Aug 2017, 19:14
I think it runs on 18v. I modded one some 8 years ago, but i dont remember the voltage for sure.
rs
Has thanked: 99 times
Have thanks: 7 times
Postby akestromer » 09 Sep 2017, 20:13
I found the schematic for the HH VS Musician that has the effects DIN connector.
Looks like it's feeding the pedals +-48v. Does that sound familiar?
If so I'm afraid that's the end of this project...
akestromer
Next
Users browsing this forum: No registered users and 11 guests
cron
